Question about Candy CDC266 Dryer
Candy cic 60 fiter light
The filter light on my cic 60 won't go out,and theres no heaty.I've cleaned the filter and everything else I can find.could it be the small pcb at the top of the dryer?
Faulty exhaust thermostat or heater and thermostat complete, check for continuity should be normally closed (complete circuit)
Posted on Mar 10, 2008
When I turn off the ignition, shut the door, and lock my car the radio and main console lights won't go off for about 5 minutes. This is a new problem and everything I've tried won't get the...
is it a cavalier or sunfire in the door there is a dome light switch this allows you to listen to the radio or put thwindow up or down for 30 to 60 seconds sometimes the door switch shorts out on the drivers side you can test by taking the pass door switch and change for drivers door if not a short to body modual
Sep 14, 2011 | Chevrolet Equinox Cars & Trucks
My dryer won't work! The light works and the lint
I believe that everything else is fine rather it is the thermal fuse that is located inside the rear panel to the exhaust duct that is bad and should be replaced. If you want you can test this fuse for continuity and if it is bad then it should be replaced, as it cannot be reset. If the fuse is fine then it can be due to the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Aug 27, 2011 | Kenmore Dryers
Wash cycle stops and light on the extra dirty symbol lights up
This is might be the drain filter. When the drain filter is clogged, the machine won't empty itself of water.
Candy has a troubleshooting webpage that lists many possible problems/solutions:
If you do try to check the filter, keep in mind that opening the drain filter will yield gallons of water on your floor, especially if your machine does not have the drain hose next to the filter opening. You'll need to have some way of transferring the water ready before opening the filter.
Good luck from Detroit, MI.
Jul 18, 2011 | Candy Washing Machines
I have the Candy C1C60, the "clean Filter light will not go off
I had the same problem, cleaned the whole machine until it was back to show room condition but the light was still on. Turns out my heater had packed in, bought a replacement and fitted it and it down the trick (no light and drying clothes)
Jan 03, 2010 | Candy CDC266 Dryer
Candy cic 60 keeps tripping electric
take cover off fan and see if there is signs of water there. a common cause of tripping is that water is thrown up from the fan onto the element.
get back to me if you find this
Aug 13, 2008 | Candy CDC266 Dryer
Candy CIC60 01 Tumble drier
Hi you need a new heating unit which is behind the back casing. Price approx £42 plus labour
Jun 01, 2008 | Candy CDC266 Dryer
FUJITSU 3500 stylistic
plz intall service pack 2 (download it from
May 12, 2008 | Tablets & eReaders
The Candy CIC 60-1
replace the element
Dec 30, 2007 | Candy CDC266 Dryer
Candy CDC266 Dryer Logo
214 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
