Question about Toshiba 42H81 42" Rear Projection Television
Cleaning the screen
Can you tell how i can clean the screen as it has some green marks on it thank s
Clean your screen with soap and water or a Windex like sollution like you would a window. For the cleaning cloth, use a cotton rag or towel. Have a great day
NC Electronics
Mills, Wyoming
Posted on Jan 06, 2008
What is the rule when cleaning ball by rubbing on green
You are not permitted to alter the surface of the green except by removing loose sticks leaves etc which impede your putting line, and to repair pitch marks, which should be done as soon as players arrive at the green. So no, it isn't allowable to rub the ball on the surface of the green. You can't even repair spike marks before everyone putts out, although you can when everyone has left the green. It is a 2 shot penalty to break this Rule 16.
You are allowed to clean the ball by marking THEN lifting it. Use a towel, which is a standard golfing accessory.
Jan 02, 2017 | Televison & Video
We cleaned the inside of our tv and now we have a green screen
Please tell me how you actually cleaned it? Seems you may have hit something that turned the Green CRT gain up higher than the blue and red CRT?
Dec 07, 2014 | Hitachi Televison & Video
Dirty marks on samsung pictures not the view finder ES73
You need to realize that the screen has 1 million pixels max, while the camera sensor has 12 million pixels. On the LCD you can barely tell whether something is in focus, right?
So if there is dirt or a smudge on the lens, or inside the camera on the sensor itself, you'll be much more likely to see it when you look at the final picture on the monitor.
Clean lens with a microfibre cleaning cloth (similar to eyeglasses or monitor glass) and see if that helped. Cleaning the sensor is probably a job for a camera repair shop. Good luck!
Jan 07, 2014 | Samsung Cameras
There is a green hue around the objects and people on the screen how do i fix this
Hope it is just cleaning take off the front screen. I think on that model remove the speaker covers, and a row of screws holding the bottom of the screen remove them. Watch the wires to the front buttons there may be a connector or two to undo. Carefully lift up and toward you WATCH THE WIRES. With a dry clean cloth wipe off the three CRT tops and the back mirror. Put back together and see.
If you still have a green hue.
Remove the screen again. With a flash light look down the CRT's if they a real cruddy down in the coolant yes there is liquid coolant in them. The red doesn't have this trouble but the blue and green can get contaminated. Also look for leaking of the coolant down on the boards. There are procedures to clean and repair leaks. Let me know.
There are a couple of focus procedures which I don't think is your issue.
Good luck Mark
Oct 02, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Clean the screen.
I highly recommend using an LCD screen cleaner occasionally to remove dust and debris that can collect over time - I use this on both my computer and television:
Monster Screen Cleaner
Hope that helps.
Mar 30, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Green convergence on Panasonic PT-53WX42 is not ligning up...
Does not sound like the chips are bad.
What you need to adjust is "SKEW". You need to enter "service Mode" then go into "Coarse Convergence". Skew can be adjusted for all 3 colors. Unless you have the service manual, these corrections should not be attempted.
To clean the INSIDE of the screen, you really have to disassemble the TV. Remove all the screws that hold the "back" ( the piece with the mirror) to the front (screen) assembly.
The screen can be cleaned with a solution of diluted isopropyl alcohol, no more than a 50% solution. Drugstores will carry it, but it might be 70%-90%. Just dilute with distilled water (not tap water as it contains minerals). Personally I have used 70% with no ill side effects but 50% is recommended.
Dec 08, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Flatron monitor screen - how to clean
Use a microfiber cloth and they also sell a product at wall mart in electronics for flat screen tvs monitors and so forth just for the purpose of cleaning them. But a microfiber cloth should handle the bulk of it. if not go to walmart and take a peek.
Aug 24, 2008 | Gateway FPD2275W LCD Monitor
Pioneer Avh P5700
might need laser cleaning. try a laser cleaning disc from most electronic shops
Jul 19, 2008 | Pioneer AVH-P5700DVD Car DVD Player
Mitsubishi tv model wt 46809
Good Day, sam;
Sam it depends on "smudge".
If it's an oily type; then a mild soap, like dawn, on damp, warm soft cotton type cloth may remove it.
There are products found in most large best buy, circuit stores that sell a screen cleaner. It's sold in a small spay bottle, about 2-3 ounces. Always spray onto cloth NOT screen. Always wipe/clean with up & down strokes, NOT side to side or at an angle.
If the screen is smudged after attempts of trying to 'cleanning' a scratch, then only replacing the screen will fixya problem, cost will be in the range of $100.00-$250.00.
Good Luck, hope this was helpful, big IRISH.
Jul 15, 2008 | Mitsubishi WT-46809 46" Rear Projection...
there are two screens..the lenticular..and the can try to pull them apart(very fragile!) and clean them but you must be careful not leave any water or moister between them(blowdry or wipe completely dry after cleaning with damp cloth) do not rub too hard...just spray warm water on the rag and carefully wipe clean ...then dry. Putting the screens back together isn't too tricky but let me stress..these screens cannot be bent or they will break...pull them off with two people(one on each side)..also you will have to take the front cover off because the screens are literally clamped down to the front cover.....good luck...let me know if you need futher assistance..........mike
Feb 13, 2008 | Hitachi 65S500 65" HDTV-Ready Rear...
Toshiba 42H81 42" Rear Projection Television Logo
35 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
