Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | Color is off on my tv ...
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
Color is off on my tv im seeing colored shadows
By beau_a05 on Nov 09, 2009
color is off on my tv im seeing colored shadows how do i reset that without a remote
Same Problem
Nov 18, 2009
-   SD TECH YOU SAID YOU HAVE STEP BY STEP INSTRUCTIONS FOR REPLACING CONVERGENCE CHIPS FOR WS-55809 I WOULD GREATLY THANK YOU IF YOU WOULD POST THEM-   mvdriver
Best Solution
posted on Nov 10, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 852 votes
YOU need a Mitsubishi remote to do any convergence adjustments--if convergence is skewed or bad it is most likely it will not adjust back.
WS-55809 uses two of the STK-392-570 CONVERGENCE CHIPS--95% chance both will need to be replaced and the set adjusted with the remote.
If you can do this you can save a lot of money and the set---most shops are going to get at least 300 for this kind of repair---you can buy a pair of the chips on Ebay for under 13 dollars plus shipping.
I HAVE STEP BY STEP, START TO FINISH INSTRUCTIONS FOR DOING THIS REPAIR ON THIS MODEL--IF you think you or someone you know can do it let me know and I will post the instructions here for you.
This is a common problem on ALL projection sets--the chips have a metal back and are mounted on a large metal heat sink on the middle board--a white grease--heat sink compound is applied to the back of each chip to move heat quickly to the metal and after several years from the heat it has dried out and one of the chips goes instantly.
If the set is repaired it will not have this problem for 5-8 more years----lifespan on these chips.
If you need help let me know and if this information has helped you, rate this solution as I DO THIS HERE FOR FREE.
SD TECH
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Answer
when purchasing replacement convergence IC STK392-570 are they specific to the TV brand, I see... (More)
Answer
I turned on my Mitsubishi ws 55 in TV and was going to play my PS3 when I received no picture. This... (More)
Answer
as soon as i turn on the tv it turns off it clicks on then 2 seconds later it clicks off. i self... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
