Refrigerators
Problem for Refrigerators
Generic problem for all Refrigerators
I get puddles of water inside my fridge
By sminni on Nov 09, 2009
i get puddles of water inside my fridge
Solution #1
posted on Nov 10, 2009
Not Rated)
aasc
Rank: Guru  Refrigerators  Expert
Rating: 94%, 637 votes
Remove the food and the ice maker from the freezer ( if equiped ) . Remove the rear freezer panel . Using a hair dryer , start in the middle , below the coils , defrosting , until you see the drain hole . Use hot water to help defrost the hole . Once water starts going thru the hole , use a small hose inserted into the hole , and blow thru , to remove any unseen debris in the drain line . Use an ALUMINUM solid wire , 14-16 guage , with the insulation completely off , and insert one end into the drain hole as far as possible without any force . Wrap the other end about 1 1/2 to 2 turns , around the black rod (defrost heater) , above the hole . When refrig goes into defrost , the heat will transfer from the heater , to the wire , keeping the hole from freezing up again .
Was this helpful?
Yes
No
Solution #2
posted on Nov 09, 2009
Not Rated)
scubasammy
Rank: Master
Rating: 96%, 5 votes
Sound like a condensation problem. It can be that the frig is turned up too high. (temperture) or you are putting hot food in.
Was this helpful?
Yes
No
Popular Solutions for Refrigerators
Questions and Unsolved Problems for Refrigerators
Answer
Whirlpool model ET1CHEXVB or model W2RXEMMWB. Anyone have comments on either of these... (More)
Answer
Need a new refrigerator after only 8+ years from Kennmore -- have not been happy with this brand on... (More)
Answer
my fridge sounds like its running but its not cold. i pulled it out of the box and plugged it in and... (More)
Answer
my fridge/bottom freezer stopped getting cold and the are now at room temp feel slight coolness from... (More)
Answer
doors are shut and the stupid alarm keeps going off. how do i disable this?
Describe your Refrigerators problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , CA
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
