FIC P4M 915G/PD1 Intel P4 FSB533 HT ATI PCIE Display Adapter usual array of drives Musketeer Fan/Power Controller ? [hey... it came with the machine] Motherboard been running for about 2-3 years without problem. For convenience, I've always had the Windows Power Options set for "No Saving", i.e. leave everything on all the time. My conscience was **** by recent news reports of the combined carbon footprint of PC users who leave their machines running all the time. I went into Power Options and set the Display to go off after 2-hours and the system to "sleep" after 5-hours. Some days later I went to "wake-up" my machine but no joy! THE SYMPTOMS ARE: Hit the "Power On" button and all the fans fire-up, front-panel leds & lamps come on but as soon as I release the button it dies again. If I hold the power button on, power oscillates on, off, on, off continuously at about 1 - 2Hz. I HAVE TRIED: 1. clearing CMOS - no effect 2. removing all hardware a piece at a time - no effect 3. restored hardware but removed CPU - in this configuration the power supply starts normally from a single push of the power button? Likewise, switches off correctly after 4-second press/hold of power button. 4. replaced CPU with previously unused (i.e. out-of-the-box) Intel P4 and I'm back to the original symptoms... won't power-up from single button press and oscillates if button pressed & held. 5. Retained new CPU and removed Musketeer Power/Fan controller - no effect Finally, I don't get any beeps at all in any of the above mentioned configurations and I see no sign of bulging capacitors, pcb deformation or excessive heating anywhere on the board. QUESTION: At this point my guess best guess is a dodgy motherboard but if so, then how did this happen? Apart from overclocking [not possible with my system anyway] changing sotfware settings shouldn't lead to hardware failure! QUESTION: Could it be the PSU? Since it starts/stops OK without the CPU installed, is this really a possibility? QUESTION: is there anything else to try? Many thanks
Experience a similar problem with a FIC MB. I cleared CMOS then removed MB battery for 1 hour. Restarted the unit with just the video card and hard drive installed. After unit rebooted I added sound card, network card, etc.
Posted on Jan 06, 2008
SOURCE: FIC P4M 915G/PD1 system fails to Power Up
You should always try a new power supply if possible. After all, it is one of the most likely components to fail - it's got moving parts (one or more fans), just like your hard drive (spinning platters), one of the other most likely parts to die.
That said, in this instance it probably is the mobo. FIC made great motherboards, but they got out of the business so you won't find the same one anywhere. If you have to replace it, you may be able to get out of a Windows reinstall by getting a motherboard with the same chipset, which looks like a 915/G, though any 915 based board might do. You may still need to do a repair install, but in many cases the same chipset allows you to boot and then just load all the new different drivers for the new board.
Posted on Jan 27, 2008
ftp://ftp.fic.com.tw/motherboard/bios/socket775/p4m-915gvd1
http://www.fic.com.tw/press.aspx?pr_id=138
http://www.fic.com.tw/product/motherboard/intel/p4m-915gd1.aspx
http://www.fic.com.tw/product/motherboard/intel/p4m-915pd1.aspx
photo:
http://www.fic.com.tw/product/motherboa ... 915gd1.jpg
specs:
http://www.fic.com.tw/product/motherboa ... 15pd1.aspx
download page for BIOS & DRIVERs and link to empty manual:
http://www.fic.com.tw/support/motherboa ... del_id=159
empty manual:
hope some of these help
Jul 30, 2012 | FIC Computers & Internet
Nov 20, 2010 | IBM ThinkCentre M51 PC Desktop
Nov 10, 2010 | FIC P4M-915PD1 Motherboard
Dec 10, 2009 | FIC P4M-865G MAX Motherboard
Jul 22, 2009 | FIC P4M-915PD1 Motherboard
Dec 19, 2008 | FIC P4M-915PD1 Motherboard
Nov 25, 2008 | FIC P4M-915PD1 Motherboard
Apr 08, 2008 | FIC P4M-915PD1 Motherboard
Jan 06, 2008 | Intel Motherboard
Sep 07, 2007 | FIC P4M-915PD1 Motherboard
Jul 06, 2008 | FIC P4M-915PD1 Motherboard
114 people viewed this question
