Question about Fisher and Paykel DEGX1 Electric Dryer
DEGX1 Drum not working
I tried drying a pilliow last night and I hopped in the shower, when I got out to check if the pillow was dry, i opened the lid and the silver barrel was closed all the way around. I held down the tab and got it open, but now nothing works! PLEASE HELP!
  • 92 Answers
Did you try unplugging the unit fir 60 sec. otherwise i suggest getting a sevicer. as these machines are easy to work on only if you are familiar with them
Posted on Jan 20, 2008
I have tried drying a pillow on every setting but they come out damp. The dryer automatically assumes the items are dry and refuses to continue with the dryer programme. Is there an override function?
for driers to work , the air has to circulate in and around the object being dried and by nature pillows do not allow this to happen
hang it on a line in the sun to dry is better and more efficient
Aug 12, 2016 | Dryers
try to unplug unit 1st 5 min then back in see if u get reseted if not let me know will go to next step
Feb 01, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Samsung front load dryer will turn on but not spinning or drying. I was wiping it out and turning the drum I heard a snap sound.
I was cleaning mine and doing the same thing last night. Washed a load of clothes tonight and went to dry them and everything works on it except it won't spin or heat. Heard the same type of popping noise last night cleaning it out. Have you found any solutions? Mine is just over a year old. I did some reading and thing that the dryer belt came off its assembly possibly. Have you found a solution?
Jan 10, 2011 | Samsung Dryers
I have a whirlpool duet dryer.. I need to know how to put in the rack for the tennis shoes.. HELP
Hi dear.Here is some help from the user manual.I hope that helps.Thanks. DryingRack
To use the drying rack
Do not remove the lint screen.
1. Open dryer door.
Place drying rack inside dryer drum, positioning the back wire
on the ledge of the inner dryer back panel. Push down on
front edge of drying rack to secure over the lint screen.
Put the wet items on top of the rack. Leave space between
the items so air can reach all the surfaces.
NOTE: Do not allow items to hang over the edge of the rack.
Close the door.
5. Select a timed drying cycle and temperature, or an air cycle
(see following chart). Items containing foam, rubber, or plastic
must be dried on a clothesline or by using the Air Only
temperature setting.
6. You must select a time by pressing MORE TIME or LESS
TIME. Reset time as needed to complete drying. Refer to the
following table.
7. Press (and hold) HOLD TO START button (about 1 second).
NOTE: You must remove rack for normal tumbling. Do not use
automatic cycles with the drying rack.
This chart shows examples of items that can be rack dried and
the suggested cycle, temperature setting and drying time. Actual
Rack Dry Setting Temp. Time*
Wool Sweaters
Block to shape and lay flat onthe rack.TimedDryLow 60
Stuffed toys or pillows
Cotton or polyester fiber filledTimedDryLow 60
Foam rubber filled
N/A Air Only(noheat)90
Sneakers or canvas shoes N/A Air Only(noheat)90
drying time will depend on the amount of moisture items hold.
Aug 30, 2010 | Whirlpool Duet Front Loading Dryer Rack...
My Sharp ES-A50S washing machine won't spin dry. the alarm warning that the lid is open always sounds off even though I closed it already. what should I do????
ok your problem is due to some problem with lid sometimes a heavy wait on lid of dry drum makes it settings wrong alignment is not correct plz call the mechanic there it will fix
Sep 14, 2009 | Washing Machines
Wont start. Extra dry light on and cool down light on.
Fault #3 Drum Stalled; unable to move.
  1. Check drum movement mechanisms: belt, motor and motor harness (if motor moves drum slightly, treat as fault #2)
  2. Replace the motor control module.
  3. Replace the motor.
Fault #2 Drum Gap Cannot be Located
  1. Ensure sensor module is correctly located and clipped in.
  2. Replace the lens on the sensor module.
  3. Replace the sensor module.
  4. Remove Top Deck and clean the sensing bumps on the outside of the drum end.
  5. Replace the drum.
May 02, 2009 | Fisher and Paykel DEGX1 Electric Dryer
Thumping noise in atlantis dryer after drying heavy mattress pad
Have you husband do a visual inspection of the drum and literally feel it to see if anything is caught or stuck on the drum. The motor also may have something caught in it as well. This would be the motor that turns the drum.
Dec 15, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
My fisher paykel dryer does not dry properly. I have to run 2 cylces to make the clothes dry
If you have to run the dryer 2 to 3 times as long to dry the clothes then you just need to make sure the vent hose behind the dryer isn't kinked up and the vent is open all the way out side ,,, that will fix it for you.
Nov 25, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Kenmore model #110.26442502
Hello dagreen,
Welcome to fixya.
I'm Huuum and happy to assist you,
You said,
Last night you filled the washer with a comforter and pillow cases! It was working fine and then you lifted the lid. Now it wont start back. Any ideas. It is full of water and had already started agitating.
Check the breaker
Could the power be out due to an electrical storm while you were sleeping.
If not!
Try pulling the plug out for 5 minutes or turning the breaker off if you can't reach the plug.
Then try to start. this should have reset the system.
Some Questions to check
• Is the drain hose clogged, or the end of the drain hose
more than 96 in. (244 cm) above the floor? See the
Installation Instructions for proper installation of drain hose.
• Is the lid open? The lid must be closed during operation.
Washer will not agitate or spin with the lid open.
• Is there excessive sudsing? Always measure detergent.
Follow manufactures directions. If you have very soft water,
you might need to use less detergent.
let me know how you do and that it works.
please remember to leave a rating when your finished.
Sep 26, 2008 | Kenmore 24032\24036 Top Load Washer
Fisher and Paykel DEGX1 Electric Dryer Logo
99 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
