Question about Sewing Machines
Sewing machine missing stitches
My sewing machine was working fine until I tried to sew through a velcro tape that had a sticky side. Then it wouldn't stitch at all. I changed the needle and cleaned where I could, but even so it is still skipping stitches.
SOURCE: Sewing machine straight stitch is not straight
Hey. It's full out possible that you have it on the right setting...but concider this - the switcher inside the sewing machine could be broken (ie. It's moving to different stitches - but not the one you have the outside set for)
It happened to me (pc o crap singer model)
Posted on Jan 24, 2008
  • 188 Answers
SOURCE: needle stuck in right position, will only sew tiny,tiny stitches
oil it. down the shaft if you can get to it. and where ever there is a hole it always helps.
Posted on Mar 26, 2009
  • 43 Answers
SOURCE: skip stitch
The three most obvious causes (other than that of the machine possibly being slightly out of time) are:
1) Too small of a needle size - increase the size.
2) A needle that has a flaw / defect - change the needle.
3) Needle not inserted correctly, either not pushed all the way up into the needle bar, or not installed facing the correct place. On this machine, the small "scarf" in the needle (an indent just above the eye) shouldface the right side of the machine.
Posted on May 07, 2009
  • 980 Answers
SOURCE: Skipping stitches while zig-zagging
If you have put a new needle in then the chances are the machine has gone out of time, you can either take it in to the repair shop or you can contact me and I will attach timing instructions
Posted on May 14, 2009
  • 1388 Answers
SOURCE: my white sewing machine is skip stitching
Check the timing of the needle to the hook.
Here is a guide to generic principles of Timing
Posted on Aug 27, 2009
  • 268 Answers
SOURCE: Whenever I zig zag my machine skips stitches.
Try these solutions.
* Re-thread your needle
It may be threaded incorrectly (backwards).
* Reinsert your needle
Make sure it goes all the way into the holder and that it’s positioned correctly – usually with the
flat side away from the bobbin, but consult your machine’s manual to be sure.
*Change your needle
Your needle may be blunt, bent, or otherwise damaged.
*Your fabric may require a different needle. Generally, heavier fabrics require larger needles and
thinner fabrics, smaller needles. You may also need a larger needle if
you’re sewing through many layers of fabric. And make sure to use a ballpoint needle for knit fabrics and a sharp needle for wovens (or a universal needle for either).
And make sure your needle is appropriate for the type of thread you’re using.
* Adjust the pressure of your pressure foot
It may be too light for your fabric.
* Change your thread
If your upper thread and bobbin threads are different types, try using the same thread for
both. And use a good quality, brand name thread.
* Adjust your thread tension
It may be too tight or too loose.
* Re-thread your machine
It may be threaded incorrectly.
* Change your needle plate
Try switching to a needle plate with a smaller hole (a straight stitch needle plate).
Important: If you change your needle plate, check to make sure your needle aligns perfectly with
this smaller hole before starting to sew. A misaligned needle could hit the plate and break, which
could be dangerous. And make sure to change your needle plate back for zigzag and other wide
I hope this helps you.
Posted on Sep 15, 2009
Testimonial: "great advice!"
0 characters
1 Points
My thread cutter cuts the top thread with every stitch
that is a possibility and is a reason that I don't use self adhesive velcro any more
I just put in a new needle and that fixed the problem
if it started with the velcro then that should fix it
Jun 19, 2015 | Great Plains Ind. Juki TL-2010Q 1-Needle,...
Thread breaks when trying to sew velcro (with sticky back substance) on rayon material. e
Use a larger diameter needle and sew at half the speed also, find Velcro without the sticky backing. that will ruin your machines lower thread paths (Bobbin case and hook areas) and cause more issues when you are done with the Velcro sewing.
Jan 31, 2014 | Singer Sewing Machines
Own Brother PC-420. Automatic thread cutter does not leave long enough tail on thread. I have to pull thread out a little further before sewing again. If I don't, the machine skips stitches for an inch...
The length of the trim is not adjustable on that machine, most arent. Theres a small piece of velcro near the cutter arm that holds the thread in place when its cut. Its commonly missing...
Sep 29, 2013 | Brother PC-420
This morning the top loading bobbin cover wouldn't quite fit right - I thought something was wrong. When I sewed it jammed seriously - and the bobbin case popped out. I realized after a solid year of...
Unthread the machine and remove the bobbin case. Check the bobbin case for any nicks, cuts or burrs and polish them off with very fine sandpaper. Replace and rethread and see what happens.
Jul 28, 2011 | Singer 7462 Mechanical Sewing Machine
I am having the same problem as angelmdb.. I have a new computerized futura and am trying to just straight stitch with it.. it starts off fine for about 8 stitches then beeps and stops.. i wait it will do...
Go to and under customer support, look at frequently asked questions, they have alot info there. If, that doesn't work for you, call customer service at 1-800-4singer and they can advise you
Sep 20, 2010 | Singer CE-200 Quantum Futura Computerized...
In the middle of sewing some tulle my machine stoped threading the stitches , i had a look and the needle was covered in something rather sticky! has this happened to any1 else!~?what could be causing the...
Yes, if there is an iron-on adhesive being stitched over.
A bead of Sewer's aid along the seam line in advance of stitching will keep the needle clean - but, with tulle, it may not adhere.
Try it on the top thread by running a bead of SA down the side of the spool to lightly coat the thread.
Mar 19, 2010 | Brother LS-1217 Mechanical Sewing Machine
I always have problems with loading the bobbin, when I think it is loaded properly and begin sewing, it balls up and doesn't stitch properly on the back side of the fabric. Top stitch is fine, underneath...
the bobbin case has a small screw on the side for adjusting the tension, use a tiny screw driver to finely adjust the tension and sew on a scrap until the stitch looks good always turn the screw clockwise to turn the tension up and counter clockwise to loosen it
Dec 13, 2009 | Bernina Sewing Machines
Why won't my new home mx 3123 sewing machine hold a stich. My machine makes 1 stitch about every 10 times the needle goes down.
Most likely the needle is inserted backwards. It needs to be inserted with the flat side of the needle to the back.
If that is not the problem, the hook timing may be off which would need a technician to look at it.
If you have sewn something with glue such as sticky backed velcro, the needle, hook and bobbin case may become sticky and prevent loop formation. Clean these with cotton and alcohol.
Oct 24, 2009 | Sewing Machines
Bobbin sewing loose
hi there,
there is a problem on tension adjustment and setting of stitch
try to learn on actual video how to set thread and sewing, log on on search box type Husqvarna sewing machine
and theres a lot more tricks on sewing.have a nice day don't forget to rate me. thank's
Apr 22, 2009 | Husqvarna Sewing Machines
Sewing Machines Logo
263 people viewed this question
Top Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Are you a Sewing Machine Expert? Answer questions, earn points and help others
