Anyone can help with fixing this ? I know what is the problem, but I can't identify the part type or find it anywhere to replace it.
the power transformer( I am not sure it is called that) need replacing, but I am unable to find it anywhere
there are two codes on the transformer: BCK-4934 THT2896
I am welling to pay for fixing this.
Comments:
Nov 10, 2009
- Hi palaboy,
Sorry for the late reply, and thank you for taking interest in my post.
I have managed to take some pictures for you to look at.
The transformer or inductor I am not sure what it is called, has 6 terminal pins on each side, and an E shape like insets from both sides.
I have looked at what you called the MOSFET, and the text written on it are "PC817 Sharp" ( I have circled them in the picture)
http://www.thabet.net/PCB/100_2215.JPG
http://www.thabet.net/PCB/100_2217.JPG
http://www.thabet.net/PCB/100_2219.JPG
http://www.thabet.net/PCB/100_2222.JPG
Thank you again.
Nov 11, 2009
- The TV was working ... there was only a buzzing sound coming from the back, I opened the LCD and the sound was coming from the transformer (The yellow part in my pictures) I Removed the transformer to found that the plastic ,at one side, melted at the pins....
and now I am looking for a new transformer or someone who can fix the old one or something...
I can even send the parts to that person for fixing.
as i am looking for your suppose replacement transformer ??
try to find the MOSFET that is connected to that transformer and post it.
that transformer could be the standby supply? or the main supply?
Comments:
Nov 09, 2009
- or send a link where i can see the board, or the image or post it.
Nov 09, 2009
- include these in your search the osc IC near to it
maybe like these
you may need to use a magnifying glass to read the label
Nov 11, 2009
- "PC817 Sharp" is an optocoupler it rarely goes bad, except when the main regulator output transistor is always get busted.
post the other part number that you can see ( regulator )
Hint: the regulator ( output IC) is directly connected to the transformer you are looking.
follow the blue arrow
Nov 11, 2009
- the two are the Regulator Output Transistors it is controlled by PC817 and there is an oscillator IC driving the said transistors Actually they are Power FET's
Nov 11, 2009
- like wise with these blue arrows
Nov 11, 2009
- here is the main osc IC
Nov 11, 2009
- verify if the chopper transformer windings is still OK , you might have an almost zero resistance if it is still good.
there should be good resistance on the primary and the secondary.
the primary is the one near to the main cord and the secondary is going to the diodes with the capacitors.
if the windings still good and no burns or burnt coil , you can put it back later and dip it to an electrical
varnish after having to put it back, before bringing it back to the board.
you should also have voltages on the primary of the chopper would be equal to the voltages on
the 180 uf 450V capacitor.
if you have step down transformer might be better to use it first when doing these steps.
Nov 11, 2009
- since the transformer is already extracted , and we're still looking for one
i have found one that might be similar to your power board
My Astar LTV-2701 wont turn on. the ''stand-by'' light works so I know it is getting power, but...
(More)
My Astar LTV-2701 wont turn on. the ''stand-by'' light works so I know it is getting power, but otherwise nothing happens when you try to turn it on. this includes using the power button on the TV itself, not the remote.
i got astar model ltv27bg serial; no 060427B1000491 i need a manual also when you turn on the tv it...
(More)
i got astar model ltv27bg serial; no 060427B1000491 i need a manual also when you turn on the tv it won't do anything what would cause that?
