Casio BG191 1B2 Baby G Watch Logo
Posted on Nov 09, 2009
NEED TO CHANGE THE TIME ON MY G 3786 NEED TO SET HANDS BACK ONE HOUR
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 09, 2009
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
1613
Points
27
tip
How To Set The Time/Calendar For Your Seiko Watch
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br /> <ol> <li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br /> <ul style="font-weight: bold;"> <li>For models with date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol> <ul style="font-weight: bold;"> <li>For models with day and date calendar</li></ul> <ol> <li>Pull out the crown to the first click.</li> <li>Turn the crown until the previous day's date appears in the calendar frame.</li> <li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li> <li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li> <li>Adjust the time by turning the crown in the desired direction.</li> <li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
on Feb 15, 2011 • Watches
1helpful
2answers
My Citizen Skyhawk analog UTC hour hand is alway 1 hour ahead of the UTC digital hour. I've tried reset and the hour/min hand alignment process without success. Any ideas other than sending in the watch...
You've gotta go to the set setting, one click out on the knob and cycle through all the timezones using the B button (the lower one) to change all the settings to OF (for winter) or ON (for summer time). According to their website FAQ, they can't determine when daylight savings time goes into effect for all the different time zones so there is no automatic changeover from SMT to normal and back again. Disappointing, I know. I just spent half an hour going through their website looking for some master switchover as well.
3helpful
2answers
My g-shock ga-110c-1a hour hand is 6 hours ahead. The digital time is correct but the hour hand is six hours ahead. If i set the time at 6:00pm the hour hand will move to 12:00. the minute hand is fine, i...
go to support page on casio. and get your manual. youll probably gonna look for a 3 or 4 digit number located at the back of your watch. once you got the manual. go to page 4. and follow the steps of "Hand Home Position Correction". that should fix it.
i also have ga 110c and i have encountered this issue
I have a quartz president wall clock, I changed the battery and set the time OK but the chime needs setting and I have no instructions as it is a very old clock
These are general quartz wall clock instructions as I dont know enough about what type/style of clock you have.
  • Open the access door to the dial and hands of the clock if required. Some battery-operated clock movements are sealed inside the clock case with a back panel that is screwed in place. To gain access to the hand set knob, remove the back panel screws using the appropriate tipped screwdriver.
  • Turn the minute hand (or turn the hand set knob at the rear of the movement if access is available) carefully counterclockwise or clockwise until the correct time is reached. Keep in mind that using the hand set from the rear would require turning the knob in a clockwise direction in order for the hands to turn counterclockwise.
  • Move the hour hand carefully with your fingers near the center of the hand to the hour that the clock is striking if the striking chime is not counting the correct hour. The hour hand is a friction fit hand and will move without engaging the minute hand.
  • Replace the back panel and tighten the screws with the screwdriver if removal of the back panel was necessary to access the hand set knob.
  • Close the front access door if required.
  • Aug 15, 2010 • Watches
    1helpful
    I have a Aerospace model watch and am having difficulty in adjusting the digital time to be equal to the minute and hour hand time.
    Its best to change on the hour.Stop your watch so that the second hand is pointing to 12.
    Move the hands to the time i.e 10am then advance the minute hand 5 mins past the hour, then turn it back to 10am, when the time comes push set and your hands are set.
    I think you might have not moved the minute hand forward 5 mins and back.
    You can now set your digital time from your hands setting.
    Need instructions for my sr927w accurist watch
    QUICKSTART - SET THE TIME
    1. Push the bottom right hand button until the mode hand indicator points to TME.
    2. Press and hold the upper left button for three
    seconds. The hour and minute hand will retract to the 12
    O’clock position.
    3. Select the time zone on the digital display by pressing the
    upper right button or the lower left button.
    4. Pull the bottom right button out one click. The bottom part of
    the digital display will start flashing. Press the
    bottom left button to adjust for daylight saving time.
    5. Press the upper right button. You will see the seconds
    flashing on the lower half of the digital display. Press the lower
    left button to reset the seconds to 00.
    6. Press the upper right button. You will see the minutes
    flashing. Press the lower left button to set the minutes to your
    current time.
    7. Press the upper right button. You will see the hours flashing.
    Press the lower left button to set the hours to your current time.
    8. Press the upper right button. You will see 12H or 24H
    flashing. Press the lower left button to switch between 12 hour
    and 24 hour.
    9. Push the lower right button back in.
    SET THE CALENDAR
    indicator points to CAL.
    2. Press and hold the upper left button for three seconds. The
    hour and minute hand will retract to the 12 O’clock position.
    4. Pull the bottom right button out one click. You will see the
    month flashing on the digital display. Press the lower left button
    to change the month.
    5. Press the upper right button and the date will begin flashing.
    Press the lower left button to change the date.
    6. Press the upper right button. You will see the year flashing.
    Press the lower left button to change the year.
    7. Push the lower right button back in.
    SET THE ALARMS
    indicator points to AL1, AL2 or AL3.
    4. Pull the lower right button out one click. You will see ON or
    OF flashing on the digital display. Press the lower left button to
    turn the alarm on or off.
    5. Press the upper right button. You will see the hours flashing.
    Press the lower left button to change the hour.
    flashing. Press the lower left button to change the minutes.
    SET THE TIMEZONE
    1. Setting the time zones allows you to add or remove cities on
    the digital display or switch between daylight saving and
    standard time. Begin by pressing the lower right button to move
    the mode hand indicator to SET mode on the bottom dial.
    2. If the hour or minute hands are obscuring the digital display,
    press and hold the upper left button for three seconds. This will
    cause the hour and minute hand to retract to the 12 O’clock
    position.
    3. Now pull the lower right button out one click. You will see the
    digital display flashing. Press the upper left button to select
    SET to display the city or OFF to not display the city. Press the
    lower left button to turn summer time on or off. Summer time is
    indicated on the lower part of the digital display. Daylight
    savings time must be manually set for each city.
    4. Pressing the upper right button will allow you to scroll
    through all the cities. After setting, push the lower right button
    back in.
    USING THE TIMER
    1. Press the lower right button to move the mode hand
    indicator to TMR mode on the mode dial.
    position.
    3. Pull the lower right button out one click. You will see the
    minutes flashing in the digital display. Change the minutes by
    pressing the lower left button. Once you have set the minutes
    on the timer, push the lower right button back in.
    4. Pressing the upper right button starts and stops the timer.
    5. Press the lower left button when the timer is stopped to reset
    the timer to its initial preset time.
    USING THE CHRONOGRAPH
    1. To use the chronograph press the lower right button to move
    the mode indicator hand to CHR mode on the mode dial.
    3 .To start or stop the chronograph press the upper right
    button. If you press the lower left button it will display the split
    time for 10 seconds.
    4. When the chronograph is stopped press the lower left button
    to reset back to zero.
    SET THE TIME ZONE
    the mode indicator hand to SET mode on the bottom dial.
    savings time must be manually set for each city..
    through all the cities. After setting, Push the lower right button
    back in one click.
    Hope this helps. =)
    3helpful
    2answers
    Changing the hand time only w/o changing the digital time
    For Casio Waveceptor:
    --- A
    ( ) Button Reference
    --- B
    Set in correct order:
    1) Hand Home Position
    2) Digital Time Set
    1) Hand Home Position:
    Press and hold A and B for 5 seconds, Press A to move Second Hand to 12: position: (if not there). Press B to enter Hour/Min set mode. Press A to move both hands to 12: position. Hold A to move hands fast, Press A again to stop hands. All 3 hands are now at 12' oclock.
    Press B to exit Hand Home Position mode and enter Timekeeping Mode.
    2) Digital Time Set: (hands will self set when done)
    Press and hold B for 5 seconds to enter setting mode.
    Press A to advance current item or scroll through choices. Press B to set item and advance to next item.
    <Order of Items to Set>
    GMT Differential -> Daylight Savings auto/on/off -> Seconds -> Hour -> Minutes -> Year -> Month -> Day -> Day of week language -> Auto receive -> (back to Timekeeping Mode).
    <Setting each Item>
    GMT Differential: Press A untill your time zone is reached (E=eastern, C=central, M=mountain, P=pacific). Press B to set (advances to next item).
    Daylight Savings: Press A untill desired DST mode is reached: ("At" auto, "On" after spring change, "Of" after fall change) Press B to set (advances to next item).
    Repeat to set: Seconds (resets to :00), Hour, Minutes, Year, Month, Day, Day of Week Language, and Auto Receive (on/off).
    For each item, Press A to advance, and B to set.
    Pressing B to set last item exits Setting Mode and enters Timekeeping Mode. Hands advance to current time.
    Good luck,
    Techjoel
    Need instructions on National Geographic Men's watch #NG010GYSK
    go to Buliva web site and look for the chorograph 561/598
    FEATURES
    1. Hours, minutes, seconds and date display.
    2. 60 minute Chronograph (CHRONO) with minutes and
    seconds display.
    3. 24 hour hand, permanently synchronized with the normal
    12 hour hand.
    A. SETTING THE TIME
    1. Pull the crown out to position “3” (See diagram). If the crown has
    a “screw-down” lock, then unscrew the crown lock first by turning
    the crown toward you, then pull it to position “3”. Do not forget to
    screw the crown back “IN” after all setting is completed.
    2. Turn the crown towards you (hands moves clockwise) until the
    date changes at approximately midnight.
    3. Continue turning the hour and minute hands to the correct time.
    If it is afternoon you must go past 12 o’clock again (noon) to set
    the correct time.
    4. When the correct time is set,push crown back to position “1”.
    B. SETTING THE DATE
    1. Pull crown to position “2”(See proceeding diagram).The watch
    will continue to run.
    2. Turn the crown away from you until the correct date appears.
    3. Once the date is set, push the crown back to position “1”.
    Note: Do NOT set the date between the hours of 8:00 PM and
    3:00 AM.This would not damage the watch,but the date may need
    to be reset later.
    C. CHRONOGRAPH (CHRONO) ADJUSTMENT
    If the chrongraph second hand is not positioned at the proper
    starting position (12 o’clock or “zero” position), use the below
    procedure.It does not need to be repeated unless the watch
    receives an impact sufficient to move the hand out of position, or
    the Battery has been changed.
    1. Pull crown out to position “3”.
    2. Push button “A” to move the Chrono Second hand (long hand) to
    the “0” or 12 o’clock position. Each button push will move the
    hand one step – BUT holding the button down will advance the
    hand rapidly.
    3. Push crown back to position “1”.
    D. USING THE CHRONOGRAPH (CHRONO)
    Note:
    The maximum chrono reading is 60 minutes, However the
    chrono will continue running once 60 minutes has passed. The
    resulting one hour periods may be added together mentally to keep
    track of longer periods.
    For example – If you know that approximately one hour has
    passed since you started the chronograph, and the chrono reads
    25 minutes, then you know that the chrono has been running 60
    minutes plus 25 minutes, which is one hour and 25 minutes.
    1. Push Button “A” to start the chronograph. Push button “A” again
    to stop the chronograph.
    2. Push button “B” to return the two chronograph hands to the
    “Zero” or starting point.
    3. The Chronograph can be stopped and started again
    (Button “A”), repeatedly, to “ADD” times together.
    BOOK NO. 561/598 Chrono FS00/01/10
    Watch Setting Guide
    4/2007
    9helpful
    Casio baby G watch model 3786 (can't change digital time)
    Im a watch technician,and when im make adjustment to a new watch for me i dont need any manual,the thing ive done is keep pushing and pressing the button and observed what happen and the result i write what im discover new to me.When setting a baby g watch find the set and press it for 10 seconds.then your watch will flashing then go to mode button and choose what you are going to set.The hour ,the date ,the alarm whatever is there to set desame you going to do , only the set button need along press.Message me whatever you discover .
    Top Casio Watches Experts
    k24674
    Robert
    ZJ Limited
    ZJ Limited
    Are you a Casio Watch Expert? Answer questions, earn points and help others
