Question about Gateway Media Center 610XL PC Desktop
No power
Model 610 wont turn on. are there directions on how to replace the power supply. thanks steve
    Problem Solver:
  • 3 Answers
Yeah,
look at the back of the pc ...around the fan u will see 4 srews, unsrew them to releas e the PSU unit, then unplug it from thr motherboard. check the connector that attahches to the motherboard to see if it is ATX or AT (most cases it will be ATX these days)- buy an ATX PSU and looking at the pin connectors on the motherboard replace the new PSU the same way as the pins are line up...ber in mind that if you reverse the pins you will not have no power coming through or you may initiate a short circuit that might blow your board up...BE CAREFUL - if in doubt ask a friend who has changed a PSU unit before and don't be shy- It will save you a lot of money
Posted on Jan 07, 2008
    Genius:
  • 1,067 Answers
Reg desktop computer ? 4 screw on back unplug it out buy new one atx style for latest computer sum use mini small power to fit in smaller cases micro atx let me know more info
Posted on Jan 06, 2008
The monitor has a blank screen..the power button is flickering though..it has been left on for a long time without being turned off..it did have the problem of a flickering screen everytime it was turned...
Hello Steve Raywood,
Welcome, and thank you for using FixYa!
To answer your question: The power supply board in this monitor needs to be diagnosed.
If It were me, I would remove the power supply board and check for bad (cold) soldier joints and capacitors. If those are good, then I would test the +5V and -5V power supply transistors. If she knows of a local Television Repair professional, she could have all of this done for her. It may be just as easy for her to hit a sire like www.newegg.com or www. tiger direct.com and order a replacement monitor.
Have a great day!
Oct 26, 2011 | Samsung SyncMaster 216BW Monitor
Sir i have compaq 610 model named as delphi/d40. The problems are when light(electricity supply) goes off it also automatically goes off that means it doesn't take back up. please answer why it has...
Sounds like you have a problem with your battery in the laptop. When the power fails, you should have several hours of battery life even 'in the dark'. If this is not the case then you should consider a replacement battery. Here is just one of many sources for replacement batteries:
http://www.battdepot.com/model/compaq/620+notebook+pc/lhp237.aspx
You should also ensure that the charger is working when the power is on. When you go into Windows click on START --> CONTROL PANEL --> POWER SETTINGS. You should see an area where it will tell you if the battery is being charged, is fully charged or is not charging at all. If the power supply isn't working, here is a source to get a replacement for that as well:
http://www.battdepot.com/model/compaq/620+notebook+pc/ac19v90k3.aspx
I hope this response helps you out.
I wish you the very best of luck! If I can help you further, please let me know.
I strive for '4 Thumbs Up'! If I've assisted you, I'd greatly appreciate you taking the time to provide me with a favorable rating. Thanks so much!
Jun 28, 2011 | Computers & Internet
When pushing on my directional swithes to turn on my 1990 sprtster they wont stay on unles u hold them
This is right for that year model and earlier models. The '91 year model was the first Sporty to have the turn signal canceling unit.
Good Luck
Steve
Jun 10, 2011 | Harley Davidson Burgman 650 Exec...
Horn wont work no juise?????
The power for the horn is supplied by the accessories fuse along with turn signals, running lights, instrument lighting, etc. If all that stuff is working, you may wish to replace the horn switch.
Good Luck
steve
May 08, 2011 | Harley Davidson FLHT Electra Glide...
Camera wont turn on.
Hi there do not worry . It can be fixed. After fall down on the floor the lens guide pin is damaged or the power supply connection disconnect from the inside. That's why its not recognized the power supply. In both case the solution is visit service center they will fix it for you. Maximum charged is 40 - 70 USD. Thanks & waiting for your feedback.
Apr 01, 2010 | Kodak EASYSHARE M1063 Digital Camera
Coby 610-2g mp3 player wont read or turn on
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player will let your computer see it again & turn on etc.
Please follow these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Mar 20, 2010 | Coby MP-610 MP3 Player
I have Ariens Model # 1336DLE snow blower aprox 5 yrs
A volt meter or test light will be needed. Also a 12 volt battery supply ( you can use an automobile battery or your automobile)
*Please Note: before testing, make sure all wires and connections are tight and not corroded, loose, or burnt. Many electrical problems are just loose, broken, or burnt wire connections.
Test the chute rotator motor: you will need to disconnect the motor from the wiring harness.
1) connect a wire to the 12 volt supply and one of the motor leads
connect the other wire to the remaining lead
*note: positive or negative does not matter, because the chute motor will rotate either direction, and by reversing leads, the motor direction will reverse.
2) If the motor is good, now check for voltage from the snowblower engine.
Locate the supply wire to the rotator switch, with the engine running, check the voltage reading on that supply wire.
3) If the supply is good, then the switch is bad
Nov 15, 2009 | Ariens Garden
Tatung wont turn on
I have v30dmtt 29 inch tatung and had the same problem. I took the power supply out and took it to repair man. He told me it couldnt be fixed. I contacted the manufacturer and had a new one sent. The phone # is 915-771-7554 but you need to call 1-888-482-8864 to get a case #. It costs 70.00 for a new power supply unit.The part # I needed was 6693006610. I hope this helps.
Sep 08, 2008 | Tatung V23CLTT 22.92 in. LCD Television
Tried to turn it on, no powr. Replaced the power supply, little led on the mother board, but no power, no fans.
no beeps.
I tried 3 different power supplies.
I stripped out the memory and hard drive and put it in the dumpster where it belonged.
Steve
Jun 09, 2008 | E-Machines T2240 PC Desktop
Liesegang DV 610 / 3M MP 8610
http://www.eserviceinfo.com/downloadsm/29752/3M/Liesegang_MP8610/DV610.html
Mar 07, 2008 | 3M MP 8610 Multimedia Projector
Gateway Media Center 610XL PC Desktop Logo
106 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
