Question about Ricoh Caplio GX Digital Camera
Transfering pictures to computer
When i try to do this message on screen says connecting... press (ADJ) key to direct print but doesn't transfer
  • neljan Feb 26, 2008
    als ik foto's van m'n camera op de computer wil zetten krijg ik de volgende tekst: connecting press(adj) key to direct print.
  • Cazz1976 Oct 24, 2008
    I have the same problem. I don't care to use a digital card reader, I want it to work like it's supposed to.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Use a memory card reader to transfer pics and save your batteries for taking pictures.
Posted on Oct 20, 2008
Havnt got a solution just the same problem. help.
Posted on May 12, 2008
When i switchon my machiene an error occured Print Unable 52 please get me out of here regards
When trying to use your Brother machine you get the message "Unable to _____". The blank may be the word Change, Print, Scan or Clean and these words may vary from model to model.
This message is a general message and will appear for different reasons. It often indicates a paper jam or a mechanical issue. Complete the following to determine the possible issue.
  1. Check for foreign objects, such as a clip or ripped paper, inside the machine.
    Open the top cover and remove any foreign obstacles from inside the fax machine. If you see jammed paper or another item inside this area, gently pull it out and then close the top cover securely.
  1. If the error continues to appear, the machine may have a mechanical problem.
    If the error message continues to appear, the machine will need to be reset. Resetting the machine will erase all faxes in memory and the Fax Journal Report. However, there is a way to transfer faxes in memory and the Fax Journal Report to another fax machine to print them out. Do the following to transfer the data and reset the machine:
Step1: Transfer the Fax Journal Report
  1. Press Menu/Set on the Control Panel of the machine.
  2. Press the up or down navigation key until MISCELLANEOUS appears on the LCD. Then press Menu/Set.
  3. Press the up or down navigation key until DATA TRANSFER appears on the LCD. Then press Menu/Set.
  4. Press the up or down navigation key until REPORT TRANS. appears on the LCD. Then press Menu/Set.
  5. The LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the report. Press Fax Start.
Step2: Verify and Transfer faxes in memory
  4. Press the up or down navigation key until FAX TRANSFER appears on the LCD. Then press Menu/Set.
  5. If there are no faxes saved in memory, NO DATA will appear on the LCD. Continue to Step 3.
    If faxes are present, the LCD will prompt you to enter a fax number. Enter the number of the fax that you want to receive and print the faxes. Press Fax Start.
Step3: Reset the machine
After the Fax Journal Report and faxes in memory are transferred to another fax machine, disconnect the Brother machine from the power source for several minutes and then reconnect it.
If the message continues to appear on the LCD, please contact Brother Customer Service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 19, 2010 | Brother Multi-Function Center MFC-240C...
Says: Unable to Clean Consult owners manual
Dec 16, 2010 | Office Equipment & Supplies
Unable to print 5A
Dec 15, 2010 | Brother HL-4040CN Laser Printer
Changed out both the back up battery and the 4 AAA's .calculator is still not coming on. what can i try next.
When you change the batteries the display reverts to default setting. My optimistic guess is that the screen display is so light that you cannot see anything on it. This can be arranged.
A Try this before thinking of repairs.
  1. Push the ON button.
  2. Even if you see nothing, press the [2nd] key and release it.
  3. Press and HOLD the UpArrow key until the screen darkens.
  4. You may have to keep pressing UpArrow for a little while before you see anything.
B If that does not work
  1. Remove one of the AAA batteries.
  2. Press and hold the [CLEAR] key.
  3. Whileholding [CLEAR], reinsert the AAA battery and then
  4. turn the calculatoron.
  5. The calculator should display the message "RAM Cleared".
  6. Release the [CLEAR] key and then press it one more time to remove the message "RAM Cleared".
C. Third option
  1. Remove batteries including the backup battery for 5minutes.
  2. After the 5 minute period, reinsert all of the batteries and
  3. turn the calculator on.
  4. Adjust the contrast if necessary.
D. Last option
The last option requires the reinstallation of the system. So to use it you must download the TIConnect 1.6 software from education.ti.com. You must have the TI USB SilverLink or the TI Black serial cables ready.You must be connected to the Internet.
  2. Press and hold the [DEL] key.
  3. Whileholding [DEL], reinsert the AAA battery and then
  5. The calculator should display "Waiting...Please install calculator software now".
  6. Connect the TI Connectivity cable between the computer and the calculator.
  7. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader.
  8. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
If all else fails you can contact Texas Instruments at ti-cares@ti.com
Hope it helps.
Thank you for using FixYa.
Nov 21, 2009 | Texas Instruments TI-83 Plus Calculator
When I turn on the Ti-83 the screen comes up in all grayed out and can't do anything except turnoff
C. Third option
D. Last option
Ifthe message "Error! Press any key to turn unit off. Then turn unit backon." appears on the graphing calculator, quickly, remove one batteryfrom the calculator and reinstall it while the transfer is taking place.
Hope it helps.
Nov 16, 2009 | Texas Instruments TI-83 Plus Calculator
Every time I turn on the calculator, it gives me this message: Waiting... Please install operating system now after a while, the screen changes to: ERROR! Press any key to turn unit off. Then turn unit...
Read the following from the TI knowledge Base. Hope it helps
Reinstalling the OS fot the TI84Plus
How do I correct the Error Waiting...Please Install Calculator SoftwareNow message on my TI-83 Plus family or TI-84 Plus family calculator?
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need to use the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
In order to install the software please follow these steps:
1. Connect the TI Connectivity cable between the computer and the calculator.
2. Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
3. Follow the on-screen directions to reinstall the calculator's OS.
If the message "Error! Press any key to turn unit off. Then turn unit back on." appears on the graphing calculator, quickly, remove one battery from the calculator and reinstall it while the transfer is taking place.
Oct 28, 2009 | Texas Instruments TI-84 Plus Silver...
Wont turn on when new batteries were installed
It is likely that the calculator is ON, but the screen is too light to enable user to see anything. If that is the reason, you can darken the screen.
Press the [2nd] key and release it. Press and hold the UpArrow till screen darkens enough.
If that does not work, here is what the Texas Instruments Knowledge Base says about the calculator not turning on.
Here it is from the horse's mouth (TI Knowledge base)
I hope it helps.
For the TI-83 Plus Family, TI-84 Plus Family:
Caution: The resets described in these troubleshooting steps will cause a loss of applications, programs and data. If at all possible please create a backup using TI Connect™ first.
  1. Try a new set of AAA batteries.
  2. Adjustthe contrast by pressing and releasing the [2nd] key followed by pressing and releasing the up arrow; repeat as necessary. To adjust or lighten the display, use the down arrow.
  3. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR],reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and then press it one more time to remove the message.
  4. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI83-family or Ti84 Plus family to reinstall the calculator operating system (see below.)
  5. Remove all of the batteries including the round lithium battery for 5 minutes.After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
If an operating system (OS) update fails or is interrupted, the calculator will be in an inoperable state with the message Waiting...Please install calculator software now.The most common cause of a transfer being interrupted is updating the operating system on a calculator with low batteries. Users will need touse the TI Connectivity cable and the TI Connect to send the operating system to the calculator. Make sure to have the latest version of TI Connect installed on the computer.
Oct 20, 2009 | Texas Instruments TI-84 Plus Calculator
Scanner Failure, 'Power off and on' message - therefore, fax will not work
Scanner failure will not let you to make copies nad scan but you will be able to print from computer and receive fax.
Even then try the steps mentioned bellow:
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing Printing from computer,
If you are able to print from computer you should be able to receive faxes.
Try printing a test fax.
Press Menu/Setup> Then press the right arrow key to locate Tools> Then Press Ok> Again press the right arrow key to locate Run Fax Test> And press OK
Check to see if it prints a Fax test
Good Luck
Aug 29, 2008 | HP OfficeJet 7110 All-In-One Thermal...
Gestetner DSc224 starts to print black strips inside colorpages
the printer in the service program has a option for the printer to do a process control on selected number of copies that number for your machine should be lower because you print about 150 duplex pages an that is 300 single pages so go in the service menu and set the process control on some 30 pages to be done .
Follow the next procedure:
- For to enter the service mode:
1. Press the clear modes key(the yellow key)
2. Type “107” at the numeric keypad.
3. Press the clear/stop key(red key)
and hold it down until the screen
display changes (for about 3 seconds).
4. Touch “Copy Sp” on the touch screen.
In the upper right corner on the touch screen has a key named [Sp Direct],touch that key and enter with the numeric key pad the numbers:3003 and on he screen will appear [Lubricant Interval] set the interval on 30 pages and press the "#" key for to confirm the value. After that for to return to normal mode press the exit key on the touch screen several times.
Also do the [maintenance -clean/adjust] option once after 1000 or 500 pages printed. Because this is a office machine and when you print on her a lot of pages per day the machine start to get dirty.
PLEASE RATE ME IF THIS HELPS
Aug 09, 2008 | Gestetner DSc224 Copier
Ricoh Caplio GX Digital Camera Logo
103 people viewed this question
Top Ricoh Cameras Experts
Greg Cann
Greg Cann
Tony
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
