Laptop shutting down
My Advent 7011 laptop Keeps shutting down I think it's due to overheating what can I do to fix it?
  • 2 more comments
  • kalbutt Jan 07, 2008
    Cheers! I will try that - Thanks for the help.
  • tinybyrd Mar 10, 2008
    having the same problem with mine it gets extremly hot and shuts off all the time...what should i do.
  • chahat_thakk Jan 04, 2009
    i am also having similar problem with dell inspiron 1525.
    Is it safe and ok for a novice to do the practice you mentioned in the solution??
  • spocky2 Apr 04, 2009
    When I use my Advent 7011 on battery power, it turns itself off after a minute or two, even though there is still a full charge on the battery when I restart Help!
    Sergeant:
    Champion:
  • 243 Answers
A quick fix is to blow back into the vents to blow dust out.
May need to dismantle though and clean fan and maybe even remove heatsink and renew thermal paste.
Posted on Jan 06, 2008
How do you stop a laptop from shutting down?
When the overheating issue is fixed, the laptop will reset. Did you clean the radiator? Is the fan running?
Oct 09, 2014 | Computers & Internet
Advent 5712 fan
Clean the fan, vents, heatsink with a can of Compressed Air, you may have to open the Laptop to clean thoroughly. Improve air flow through the bottom and out the side vents, or your laptop's components will fail catastrophically, rendering your laptop useless. A Laptop Cooler is a option. Hopefully the Graphics Adapter and the CPU have not suffered terminal damage. The Thermal Paste may need replacing. There are sensors that, when overheating occurs, shut down the laptop to prevent a melt-down.
May 06, 2013 | Computers & Internet
My Lenovo ideapad z370 keeps shutting down and booting up for no reason?
dude .,, its due to overheating caused by busted heat sink... maybe you should replace it to fix this thing...
Jan 02, 2013 | Lenovo Computers & Internet
Sudden Shutdown due to Overheating
either your power adapter os faulty or the cooling fan inside the laptop had failed forcing the laptop to shut down as safety precaution.
Aug 29, 2012 | Dell Inspiron 14 N4010 Laptop 4g 500gb...
I have a ACER 5735 . The laptop shuts down suddenly while its on and sometimes im not able to switch on the laptop and even if i switch on , then once again the power goes off immediately . What would be...
The reason for the sudden shut down of your computer is because of overheating of the 'case', where the CPU is mounted. Overheating can be due to dust accumulation on the heat sink, which prevents dissipation of heat. The possible solution to combat overheating issue is to keep the laptop dust free by cleaning out debris at the vents frequently. Note that a laptop has a much smaller cooling area in comparison with desktops and hence laptops tend to accumulate dust a lot quicker than desktops. This is because all the dust/debris, in the case of laptops, accumulate in the cooling fins.
Get more information to fix Acer shut down issue :
http://supportforacer.iyogi.com/aspire/shut-down-2.html
Hope this information helps you.
Aug 28, 2010 | Computers & Internet
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
My laptop keeps shutting down at random times. I
If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed. Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
Good luck
Oct 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Advent laptop 7619 keeps shutting down
yes clean the fan with compressed air, and check bios and see if it is set to shut down at 105 degrees temp if it is move it up to 130%.
Jun 22, 2009 | Advent Netbook
I only need a sound driver for this Advent 7011 laptop.all the driver is installed expect for only Multimedia Audio Controller. Under the laptop. i find this number: N35AS1.
http//www.google.com and type in the search area, "dounload advent 7011 sound driver type n35as1 it will bring the options of dounloads, donuload and install
Apr 01, 2009 | Advent 4211c Notebook
Advent laptop overheating
Check the jack on the machine to see if it's loose or broken. Use a small screwdriver, and see if you can move it in any direction. If it is loose or broken, get it fixed imediately. A loose or broken jack can create an electrical arch which can do severe damage to the machine.
Jul 22, 2008 | Computers & Internet
Computers & Internet Logo
497 people viewed this question
David Payne
David Payne
