Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2...
(More)
Hi, every one My proplem in my Riso 3750 it is not work in speeds 3,4,5 he work only in speeds 1,2 when I' use paper size A4R, A4 . But when I' use paper size A3 he work normal in all speeds
Hi, i am working on a iR2016 DIGITAL copier and i have the following problems: 1) anytime that you...
(More)
Hi, i am working on a iR2016 DIGITAL copier and i have the following problems: 1) anytime that you are about to make a copy, the LCD of the machine displays change paper size but the paper size dial is still at A4 or at time during or after you have made copies. 2) When you give a copy command, the machine is unable to pick papers and displays paper jam. At times when you give a command to copy about 10 copies of a document, it will print about 3 or 4 and the LCD will display paper jam. when you open the left cover there will be no paper stacked in the machine but it will still display the same problem. I have changed the paper pick up rollers and the problem still persist. Kind Regards Nat
