Hook up of Viewsonic TV to my computer
I have a gateway 700 series with a FPD 1810 flat monitor. It has a NVDIA GeForce Ti4200 video card with 15 pin VGa and 24 pin DVI outputs to monitor.
I changed the monitor to a View Sonic N2635W TV with VGA input and HDMI input. View Sonic resolutions will support 1280x768 (WXGA). When using VGA input, I can only get a picture from the computer onto the view sonicTV using 800 x 600 resolution from computer.
When connection of DVI output from computer to HDMI input, I get "no signal" prompt on TV. When hooked up to VGA imput at anything above 800 x 600 resolution from computer, I get "not supported" prompt on TV.
When the computer reboots, it goes back to the highest resolution resulting in that I have to hook up my old monitor in order to change the resolution out of the computer to get a picture on the view sonic.
Obviously, I would like to have the very best resolution connection from computer to the TV. Also, I do not want to have to hook up my old monitor every time the computer has to reboot. What are your suggestions to solve my delima?
I have both DVI to HDMI and VGA connection cords.
Thanks for any help,
  • 70 Answers
SOURCE: Hook computer to ILO tv
The best way is to buy a graphics card with HDMI output. This will dsplay your PCs desktop the way it's supposed to look, and will appear much sharper and clearer than using vga, as the output is digital to begin with. If you don't need to play the latest games, you get get one for around $30. Add a wireless mouse and keyboard and you'll be able to control everything from your armchair. You can also then use your PC to download and watch films etc from the internet..
Posted on Jan 06, 2008
SOURCE: Intel 865G drivers
Have you tried downloading the newest most up-to-date drivers availiable? If not I would try that first.
If that fails to work, I would check and see if there are any bios updates as the video card is part of the motherboard. However, I would think that since it works without the drivers, it would be a driver issue, not bios. When you have the drivers installed, does the video show up while booting and then fail in Windows?
You may also be hitting a range or resolution that is not supported by your TV. That being said, you could check your TVs owner manual for supported modes. If you do not have your owners manual, try setting the video card at some different resolutions with a monitor, shut down, plug back into the tv, and then restart the computer. If you find one that works, great!
Posted on Feb 27, 2008
SOURCE: problem connecting DVI input of TV to DVI-D output of video card
For error code 0122, Don't play the movie or load your movie program until you have the resolution you want and have it set to display only on the hdtv . You do this by going to control panel, selecting "adjust common used mobility settings", and then clicking on "connect display. A pop-up will come up and give you the option to display only on the external display. Pick that. The thing that sucks is if you have the display set to 1920 x 1080, you can't see everything on your desktop when trying to view it on the tv.
Posted on Jul 12, 2008
SOURCE: ViewSonic TV sound but no picture
I have same problem (power light is on, and I have sound, but no picture ) and found that a small capacitor on back of power supply is blown. Seems to be common problem. But viewsonic doesnt stock. Part number is b-00005352 and im trying to find one too
Posted on Sep 10, 2008
  • 27 Answers
SOURCE: Can't display 1440x900?
I have a different LCD TV and video card, but I have the same issue.
To work around it, I have to toggle to make it the primary output. It will not work if set to extended, or set to both screens.
Posted on Apr 02, 2009
Gateway fpd1530
If you have the appropriate cable to connect the output port of the computer to the input port of the Flat Panel TV every thing will be OK. For optimum performance you might have to install the drivers for the replacement flat panel.
Nov 01, 2013 | Gateway FPD 1520 15" Flat Panel LCD...
What dose it mean when screen says out of frequency
This error indicates that your video card resolution is set igher than the monitor can display. Try booting into safemode and changing the resolution.
Here is a link to the Gateway site spec page for that monitor.
The maximum resolution it will display is 1024 X 768 which is very low for current video cards, your card may not go that low. Check it if it does not go then you will need to get a new monitor that supports the resolution that your computer can put out.
Feb 19, 2012 | Gateway FPD 1520 15" Flat Panel LCD...
Can you replace power cord?
Sure, purchase one at
hope it works.
May 12, 2011 | Gateway FPD 1810 18.1" Flat Panel LCD...
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Cable for Gateway FPD 1520 15in. flat screen monitor
live in remote area of Nevada were can i find power cable for FPD1529 monitor???
Dec 01, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
No signal
If it is connected to a working/running machine that machine may have a video card problem. Try hooking the monitor up to another computer and see if it works there.
Nov 20, 2008 | Gateway FPD 1730 17" Flat Panel LCD...
Asking support for getting drivers to 610 Gateway desktop computer
If its just the drivers u need, go to and download it from under your model no.
Oct 23, 2008 | Gateway FPD 1810 18.1" Flat Panel LCD...
Dark screen of Gateway FPD 1520
If you can see the screen display an image upon close scrutiny, it could be that the florescent back light is burned out.
Aug 03, 2008 | Gateway FPD 1520 15" Flat Panel LCD...
Gateway FPD 1730 17 in. Flat... Problem
Try using it on a different computer, it's possible that it is your graphics card causing the problem. Check for bent pins.
Dec 20, 2007 | Gateway FPD 1730 17" Flat Panel LCD...
Televison & Video Logo
408 people viewed this question
Top Televison & Video Experts
