Question about Jenn-Air JMC7000 Microwave Oven
How do I fix a Jenn-Air JMC7000 that does not heat up items?
How do I fix a microwave that does not heat up items?
The microwave makes a loud buzzing noise and does not heat the item up. There is an odor when it is running. The ordor is like you smell when a electical appliance burns out. The control panel, lights, and turn table are working.
  • Anonymous Mar 29, 2014
    Burnt rolls to black burned morsel - cannot clear the burnt odor from microwave.......help
  • 579 Answers
The noise is coming from the high-voltage transformer being overloaded by something shorting it out. Either the magnatron or the high-voltage capacitor and diode. Replace the capacitor and diode then if still not working, replace the magnatron. Its only affordable if you do it yourself - buy the part on EBAY - lookup "universal magnatron"
Hope ya fix it!
Posted on Jan 06, 2008
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Microwave not heating
It most likely is either a issue with the inverter (power supply) or the Magnatron (main unit) in this oven.
It could be a thermal fuse inside but the noise sounds more like Inverter or Magnatron.
If not a cheap unit have a shop take a look and get an estimate.
Jun 15, 2012 | Amana Microwave Ovens
My new GE over the range microwave works fine but has a loud buzzing/humming noise when in use
This sound you describe is not normal and should be checked quickly, even if it means returning the item.
Mar 27, 2012 | GE SpaceMaker Microwave Ovens
Microwave makes a loud buzzing noise and emits a burning plastic smell
This indicates the magnetron has failed, buzzing sound and odor are classic symptoms. It is cheaper to replace than have it repaired.
Apr 03, 2011 | Kenmore Microwave Ovens
Started flashing and making popping noises, but still heated ok. Then stopprdheating and just makes a loud buzzing noise
The magnetron is most likely the problem, it heats the food and is the heart of the of the microwave oven, if it was followed by unusual odor more noticeable when you open the door that would confirm it, but that is not always the case. The cost to repair would exceed the cost of a new one
Jan 19, 2011 | Thermador MBBS Microwave Oven
The microwave is making a loud humming noise when it is on and it isn't heating. It also has a burning smell. We had this microwave repaired replacing the magnetron and diode in Jan. 2006.
sounds like same problem again.... the magnetron is what does the heating and if the display is working and just humming sounds like the mag is not coming on .... could be the capacitor but most likely the magnetron again..... i am a appliance /heating and air company out of texas we work on these things everyday and is very common problem... thanks a/c and heating unlimited good luck
Dec 31, 2010 | Jenn-Air JMC7000 Microwave Oven
I have jenn-air microwave oven model m167. Unit will come on and all programming works to heat food. Oven acts as if it is heating food,however it does not cook or heat food items. Any help with...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 28, 2010 | Jenn-Air JMC7000 Microwave Oven
Microwave won't heat, light ,clock works the microwave just won't heat the items in it.
hELLO THERE
when a microwave quits heating but every thing else is ok normally
investigate these 4 areas
Investigate these three areas if your microwave won't heat but you hear a loud buzzing or humming noise:
microwave_diode.jpg Power Diode
A diode is an electronic component that readily passes current in one direction only and blocks the flow of current in the opposing direction. If your microwave's diode has become defective, your microwave will not heat and you will hear a buzzing noise. Test the diode to determine if this is the cause of your problem. Replace it if it is defective.
picturena.gif High Voltage Capacitor
A capacitor is an electrical device which stores electricity. A defective capacitor may be why your microwave is not heating but you are hearing a buzzing or humming noise. The capacitor will have to be tested to determine if this is the cause of your problem. A defective capacitor will have to be replaced before your microwave will work again. Make sure you discharge the capacitor before you test it, though.
microwave_magnetron.jpg Magnetron
A defective magnetron is the third possible cause of why your microwave is not heating, but you can hear a buzzing noise. Test your microwave's magnetron. Replace it if it is defective.
Nov 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave comes on but not heat item
It's most likely the magnetron that has failed if it does not heat the food. The magnetron is the part the generates the microwaves. When it fails, it typically shorts out, and makes a loud hum or buzzing noise. If this is the case, it is not worth fixing since the cost of the magnetron is almost as much as getting a new oven. Sorry.
Jul 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Acts like working, but no heat.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
dgyj57we
Apr 21, 2010 | Jenn-Air JMC7000 Microwave Oven
Jenn-Air JMC7000 Microwave Oven Logo
392 people viewed this question
Top Jenn-Air Microwave Ovens Experts
William Miller
William Miller
Are you a Jenn-Air Microwave Oven Expert? Answer questions, earn points and help others
