Brother MFC 210C All-In-One InkJet Printer Logo
Posted on Nov 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need help setting up my computer with my printer
Nouveau IT, LLC
Level 3:
  • Master 596 Answers
  • Posted on Nov 09, 2009
Nouveau IT, LLC
Master
Level 3:
Answers
596
Questions
Helped
188679
Points
1479
Your request is somewhat vague but most printers can be installed by 1st: Using the software can came with the printer onto your pc. 2nd: Power off your pc and connect your printer using the paralle cable or the usb cable. 3rd: power your pc and printer on and follow on screen intructions (if any)
Good Luck
C2Solutions, Inc.
I need help setting up a printer.
well setting up most printers are almost alike. will it be hooked up to a laptop or a desk computer?
Sharp MX-2610N printer can't set-up the print job (for labels from by pass tray) from my desktop computer.
Some documents like word override the settings... you need to change/save within your document you are printing. page layout and then page set up
1helpful
Bad ESC Seq
The ‘Bad Esc Seq’ message on the MT645 indicates the printer is not recognizing some of the commands it receives in the data from the host computer system. These commends are sent in the format of Escape Commands Sequences hence the ‘Bad Esc Seg’ error message displayed on the printer.
There can be a number of reasons for the printer displaying the ‘Bad Esc Seq’ error.
The first thing that it may be worth doing would be to power the printer off then disconnect the printer from the computer system. Once the printer has been disconnected from the computer system power the printer back on again. If the ‘Bad Esc’ Seq’ message is seen when the printer is disconnected from the computer system this would tend to indicate there is a fault with the printer.
If the printer powers on OK and does not display any errors when it is disconnected from the computer system it is possible that one of two things is happening.
The first thing is that a print job has been sent to the printer using the wrong printer driver on the computer system, this will send data to the printer that it does not recognize. If this is the case the print job on the computer system would need to be cancelled and resent using a printer driver suitable for the MT645.
The other thing that may have happened is that the Emulation setting on the printer may have for some reason changed so the printer not longer matches the set up on the computer system. You may need to change the emulation setting on the MT661 so it matches the host computer system set up. The printer may need to be set to either Epson or IBM emulation depending on the computer system set up.
The Current emulation setting on the printer can be found by printing a configuration page, this can be done in the following way;
Put the printer OFFLINE
Press the MODE button
Press the DOWN ARROW until HELP is displayed
Press ENTER
The printer will print out a configuration page showing the current settings, this will include the Emulation setting. This can be checked to ensure it matches the computer system set up, or change to ensure the emulation is correct for your application.
If you are printing from Windows try printing using the Generic Text only printer driver, this will not send escape commands to the printer, so should print correctly. If you still see the Bad Esc Seq message I would recommend having a look into the connectivity between he printer and the computer system.
1helpful
Set up wireless connection canon mp620
Not sure with Cannon but i have set up wireless connections You need to install software on the computer and if there is a option for wirless tick that one This needs to be done while to computer and the printer are connected with a USB Lead Once this is done and you can print with the USB lead (The USB lead needs to establish printer and settings) you can shift the computer reboot and try wireless Thats what I have done with most of the printers i have set up Some have wireless on the LCD screen on the printer under settings
Printer connected to more than one computer.
Hello
I gonna try to help you.
1. you need all the computers connected to same network.
2. you need to share your printer from the computer where the printer is connected to.
to share
a. go to control panel->printers and rightclick on your printer click sharing.
b. then share that printer and give it a share name and then OK.
click here to see pictures exact information about sharing.
c. you also need to know what your computer that shares the printer is named.
to find out go to control panel->system settings and tab computer name. write that down
a shortcut to this windows is "windows button flag" + Pause Break button.
3. go to the computer you want to install the printer on.
this computer need to be in the same network as the one with the printer.
4. click start menu then ->run and write "\\computername" and press enter. computer name is that name you write down in c.
5. then a window should appear and you can now double click on your printer that you shared, then it should auto install. done.
6. if you can find your computer with the printer, check your firewall settings on the computer that shares the printer so the connection doesn't been blocked.
good luck, if you need more help don't be afraid to get in contact with me. true fixya forum or fixya live chat
good luck
Dell-Net
Connect mulitple Computers to one printer
Is your computer is networked or connected to each other? if its networked then you can use network printer sharing.
Because printers and networks vary, the best instructions for setting up and networking your printer should be in its users manual. Also, your network-ready printer may have come with installation software that can help you share the printer over the network.
There are three main steps you need to take when networking a printer, including the following: Enable the File And Printer Sharing setting, Make the printer available to all users, and Direct PCs to the printer.
Help me??
USB is the most common household printer to computer connection, just plug the printer in and it will walk you through the windows set-up, or put the CD from your printer in your computer and the CD set-up will walk you through the set-up, when you buy a printer ask a sales person to show you how to connect it and set it up.
Norman Weimar
Norman Weimar
k24674
