Heater blower does not work.
The heater blower does not work for my bmw 316 1997 model. The fuse of the heater blower was alright.
  • Anonymous Mar 31, 2008
    I have the same problem on a 2001 330Ci, A/C blower would work then not, then work, then not, now not all the time. Checked fuse(s) and relay behind fuse box (not sure which relay it is). Not sure where to locate the resistor for the system.
    Thanks for your help!
I have a bmw 316 and heater does not blower
Posted on Mar 20, 2009
  • 589 Answers
Sounds like the blower motor resistor (this is what gives it variable speeds) has gone out.
Posted on Jan 09, 2008
Heater relay 97 bmw
Go to the front power distribution box and check 30A fuse 20 (GRN/BRN wire) which feed power to the blower relay. When the ignition switch is in START or RUN position, the relay closes and power is fed to the final stage unit. Depending upon the state of the automatic climate control module, power output from the final stage module is applied to the blower motor. If checking all this does not solve the problem, you may have a clogged heater core
Oct 16, 2012 | 1997 BMW 3 Series
I have a 2004 Honda Accord and the heater and air conditioner blower motor does not work. Have checked the fuses and they are all fine and have checked the cabin filter and it is alright. What else can I...
CHECK BLOWER MOTOR RELAY. HOT WIRE BLOWER MOTOR.IF BLOWER MOTOR WORKS, PROBLEM IN THE BLOWER CONTROL SWITCH OR FAULTY RELAY.IF BLOWER MOTOR DONT WORK WHEN HOT WIRED.BLOWER MOTOR FAULTY.
May 30, 2011 | 2004 Honda Accord
1988 bmw 325is heater keeps blowing 30amp fuse, tried to find a short but me heater blower fan isnt working what could be the problem. cant keep a fuse without blowing
More than likely the fan motor its self is short to ground try to unhook the wires to the fan motor and install a new fuse and then turn the fan on with the wires removed and if the fuse is still good you know it is the fan motor its self
Feb 12, 2010 | 1988 BMW 3 Series
1988 bmw 325i heater blower fan
Had my blower replaced last year, but my heat does not work. I can turn it up to 91 degrees and it is barely warm. Help please.
Feb 10, 2010 | 1988 BMW 3 Series
2002 bmw x5 heater blower not working
It could be the final fan reistor they all give trouble in this model.
Nov 22, 2009 | 2002 BMW 5 Series
1998 BMW 328i heater/AC blower is not running
You have clean the blower unit , may be its dirty then . and then check the blower resistor unit for malfunction.
Aug 04, 2009 | BMW 328 Cars & Trucks
Heater blower not working
It sounds like your cabin air filter has stopped up common problem on these cars. You have to remove the glovebox to get to it. If this filter stops up, your fan will be running on high but hardly anything will come out of the vents.
May 31, 2009 | 2001 BMW 325
My heater fan as stoped working on my bmw320 d it has climate control but all lights are fine
Hello There
I'd suggest looking at the fuse to start with, This is the cause in most cases.
Hope this helps
May 08, 2009 | 2007 BMW 335i Coupe
Computers & Internet Logo
1,037 people viewed this question
David Payne
David Payne
