Circular Saws
Problem for Circular Saws
Generic problem for all Circular Saws
Cold is hot, hot is cold.
By paulkeeley on Nov 09, 2009
whenever i run the machine, cold is now hot, and hot is cold. water intake hoses are connected correctly. was working fine for 1.5 years until today. anyone have any thoughts on how to fix this?
thanks,
bob.
Comments:
Nov 09, 2009
- hi. sadly, i'm not making this up. the washer was working fine up until now. i double-checked the intake hoses before posting just to make sure i wasn't crazy. thanks.
Nov 09, 2009
- yes you're both right, switching the inlet hoses would certainly make sense. however, the problem now seems intermittent. i just tried another wash set to cold, and indeed had cold water. then i tried another, and it was hot again. something's definitely out of whack...
Clarification Request
Posted by milleraba on Nov 09, 2009
Are you making this up? Is this a test? Kidding ... are you certain you have the hot wupply attached to the hot side of the washer? absolutely certain?
Best Solution
posted on Nov 09, 2009
Helpful)
milleraba
Rank: Wiz  Tools - Building & Power  Expert
Rating: 83%, 466 votes
Hondo makes a good point ... and I dont think you are crazy.
Switch the hoses to see what happens. If it works, it works ... don't question it right now. Just give it a try.
Thanks for the response and thanks again for posting at FixYa.com
dont forget to vote.
thanks
a
Comments:
Nov 10, 2009
- Thank you for the update ...
Now, dont forget to vote ...
Thanks for posting at FixYa.com
a
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Helpful)
hondo73162
Rank: Guru  Tools - Building & Power  Expert
Rating: 87%, 30 votes
Switch the hoses on the inlets and see if it corrects it. If it still is out of wack then somthing may have shorted or broke on the temerature selector switch. But I would switch the inlets before doing anything
Was this helpful?
Yes
No
Popular Solutions for Circular Saws
Questions and Unsolved Problems for Circular Saws
Answer
18 volt makita rip saw i've bought one but not satisfied what do you think
Answer
bench pro ''10 compound miter saw will not stop running after i release the trigger switch
Answer
12 inch compound miter saw wont turn on. was working earlier.
Answer
12 inch compound miter saw wont turn on anymore, was working earlier.
Answer
I have an older Craftsman mitre saw. When i try to cut, the blade does not get to full speed, and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Circular Saws :
Top Circular Saw Experts
Rank: Guru Guru
Solutions: 1220
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Circular Saw Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
