Air Conditioners
Problem for Air Conditioners
Generic problem for all Air Conditioners
I have a RHEEM AC unit and it's not com...
By finmart1 on Nov 09, 2009
I have a RHEEM AC unit and it's not coming on. What can it possible be?
Solution #1
posted on Nov 09, 2009
Not Rated)
scarfoot203
Rank: Wiz
Rating: 84%, 28 votes
Could be the breaker,thermostat , disconnect near a/c unit.I would start there. Also the outdoor fan motor could be in-op and the compressor would shut off before you get out there to check.
Was this helpful?
Yes
No
Popular Solutions for Air Conditioners
Questions and Unsolved Problems for Air Conditioners
Answer
Looking to replace a 20 yr old Weil-McLain with a dependable, efficient oil-fired boiler for a... (More)
Answer
Our Quality: We believe that our customers should receive the highest quality Hp dv1000 battery at... (More)
Answer
My heater is flasing 4 times on the circuit board. The code on the furnace says failed to ignite.... (More)
Answer
air cond clutch coil not pulling in when operated from control cct, pulls in ok when connected... (More)
Answer
i have a ducted air temp unit. rather old.. cant get model numbers off it. compressor contactor... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Air Conditioners:
Top Air Conditioner Experts
Rank: Guru Guru
Solutions: 1200
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Air Conditioner Experts
Top Air Conditioner Repair
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
