Question about Toshiba Satellite M40-S417TD Notebook
Matrix like display
Had 2 bars on the screen some time back,now can not use my lp as can see symbols, aphabets and nubber on the screen,i think the graphic card in got,i did open the lp and also removed the graghic card fruno:V000054110 (ATI 64MB), no know where to find one .
MY IS A M40-331
  • gee1 Jan 07, 2008
    open up the laptop again and put the graphic card back in make sure you have not made any metal touch make sure everything gos back the same way restart laptop gee1
  • tarkes Jan 10, 2008
    thank for the help,but still not ok.
    also did disconect the lcd and did conect an other screen to,the problem remain.
    Problem Solver:
  • 7 Answers
When you get all those letters and weird codes on the screen, does it do that at the POST screen? If so, the only way to really troubleshoot that problem is to have another ATI video chip to replace. Other than that, i would check the LCD display for a short. you would have to take the plastic cover off and look for the ground wire (use a multi-meter to determind this). If the ground is not properly secure, then secure it with electrical tape.
Posted on Jan 07, 2008
  • 89 Answers
It looks as though the video driver is corrupted. Can you go into safe mode and uninstall the last or updated driver?
Verticall bar on the screen
A vertical bar is frequently a sign that the matrix decoder has failed.
The usual solution is to replace the display panel itself. Dependent upon the model, sometimes this may not be economically viable.
There is also a possibility that the connexion between the display panel and the motherboard may have come loose. Try removing the connexion and replacing it before you replace the display panel.
Dec 10, 2013 | Samsung Televison & Video
I have a Symbol model MC7094, it was dropped and the screen started displaying lines of bars in multi-color. I changed the touch screen thinking that was the problem; but it did not help. What could be...
Hi!
Probably something internal, electronic devices are very delicate and probably someting internal needs to be replaced. My recommendation will be to contact manufacturer for repair options.
eBookBoy
Jul 06, 2011 | Symbol MC70
Hi my name is paul and I'm trying to get more help for Statistics, there was help for finding mean, but i can't find help for standard deviation. Also, for another professor I can't figure out, by the...
Here is some help. Please read both parts attentively.
TO COMPUTE STANDARD DEVIATION AND 2-VAR STATISTICS.
I assume you know the theory. I will show you the key strokes
For 1-Var statistics
Press [MODE][3:STAT] [1:1-VAR]. You are ready to enter values in the X column.
Enter a number and press [=]. Cursor jumps to second number to enter.
Keep entering numbers and pressing [=] till all numbers are in. Press the [=] key after the last one.
Press [AC] key to clear the screen.
Press [SHIFT] [STAT] (above digit 1.) then [5:Var]. Screen displays the statistical variables 1:n ;2: x bar; 3: x sigma n; 4:x sigma n-1.
Press the number corresponding to the statistical value you want, ex 1:n . The variable appears on screen. Press [=] and it will be displayed.
To display another variable press [SHIFT][STAT][5:Var][ 1,2, 3, or 4] .
To access the sum of squares sigma x^2 and the sum of data sigma x press[SHIFT][STAT][4:SUM] then [1: for sigma x^2] or [2: for sigma x]. Press [SHIFT][STAT][6:MinMax] to access minX and maxX.
For 2-var statistics
To perform 2 variable statistics you press [MODE][3:STAT] and any of the other regression options (except 1:1-Var). A two column template opens where you enter the X and Y values. When finished entering data, press [SHIFT][STAT][5:Var]. to access the different statistics. As I assumed above, you should be able to recognize what each variable means.
ABOUT MATRICES
This post is rather exhaustive as regards the matrix capabilities of the calculator. So if the post recalls things you already know, please skip them. Matrix multiplication is at the end.
Let me explain how to create matrices. (If you know how to do it, skip to the operations on matrices, at the end.)
First you must set Matrix calculation
[MODE][6:Matrix]. Then By entering one of the numbers [1:MatA] or [2:Matb] or [3:MatC] you get to choose the dimensions of the matrix
(mxn]. Once finished entering the matrix you clear the screen.
The operations on matrices are available by pressing [Shift][Matrix]
[1:Dim] to change the dimension of a matrix (in fact redefining the matrix)
[2:Data] enter values in a matrix
[3:MatA] access Matrix A
[4:Matb] access Matrix B
[5:MatC] access matrix C
[6:MatAns] access the Answer Matrix (the last matrix calculated)
[7:det] Calculate the determinant of a matrix already defined
[8:Trn] The transpose of a matrix already defined
To add matrices MatA+MatB (MUST have identical dimensions same m and same n, m and n do not have to be the same)
To subtract MatA-MatB. (MUST have identical dimensions, see above)
To multiply MatAxMatB (See below for conditions on dimensions)
To raise a matrix to a power 2 [x2], cube [x3]
To obtain inverse of a SQUARE MatA already defined MatA[x-1]. The key [x-1] is the x to the power -1 key. If the determinant of a matrix is zero, the matrix is singular and its inverse does not exit.
Dimensions of matrices involved in operations must match. Here is a short summary
The multiplication of structured mathematical entities (vectors, complex numbers, matrices, etc.) is different from the multiplication of unstructured (scalar) mathematical entities (regular numbers). As you well know matrix multiplication is not commutative> This has to do with the dimensions.
An mXn matrix has m rows and n columns. To perform multiplication of an kXl matrix by an mXn matrix you multiply each element in one row of the first matrix by a specific element in a column of the second matrix. This imposes a condition, namely that the number of columns of the first matrix be equal to the number of rows of the second.
Thus, to be able to multiply a kXl matrix by am mXn matrix, the number of columns of the first (l) must be equal to the number of rows of the second (m).
So MatA(kXl) * MatB(mXn) is possible only if l=m
MatA(kX3) * Mat(3Xn) is possible and meaningful, but
Mat(kX3) * Mat(nX3) may not be possible.
To get back to your calculation, make sure that the number of columns of the first matrix is equal to the number of rows of the second. If this condition is not satisfied, the calculator returns a dimension error. The order of the matrices in the multiplication is, shall we say, vital.
Apr 14, 2011 | Casio FX-115ES Scientific Calculator
How to multiply matrix on fx-991ES calculator?
hi..
Its very easy to do matrix operations in FX 991ES
This calculator can operate up to three Matrices at a time, namely Matrix A (Mat A), Matrix B (MAT B), Matrix C(MAT C).
  1. First to do, is set the calculator in MATRIX Mode
    Its Easy
    Press MODE button and press 6.
    Your Display will show indication of MAT on upper side of screen to show now calculator is in MATRIX Mode
  2. Now we need to Define matrices and set its dimensions.
    This product supports matrix of order up to 3x3. That is you can operate matrix of No. of rows=3 and No. of columns=3
    To input matrix, Press SHIFT and then 4. This will Pop up Menu for Matrix. Now press 1
    Your screen will show as this,
    MAT A will be your First Matrix and MAT B will be your Second Matrix and so on.
    Press 1 , 2 , or 3 to select Matrix A , B, or C.
    here I will Proceed with Matrix A, so I press Numerical 1 Key
  3. Next screen will ask you about the size of matrix.
    Press UP or DOWN Keys to view options.
    Press Corresponding Numerical keys to select corresponding order.
  4. On Next Screen , enter values on each positions
    Press UP, DOWN, LEFT, RIGHT Keys to move around in matrix and specify each element.
  5. Now we inputed Details about Matrix A. If you want to specify other matrices (MATRIX B, MATRIX C) repeat STEPS 2 To STEP 4
  6. After Specifying required Matrices, we can tell calculator to do operations with them.
    Press SHIFT and then 4 and then It will show a menu contains
  7. For example, i need to multiply Matrix A with Matrix B, i'll enter as
    SHIFT + 4 + 3 to Input Matrix A
    X
    to enter operator (Here multiplication, You enter + - x / for corresponding arithmetic operations )
    SHIFT + 4 + 4 to Input Matrix B
    = To show Result
    Press UP DOWN LEFT RIGHT Keys to view extra fields, if any.
Hope this will help you.
have a good time with Casio FX 991ES
Mar 26, 2011 | Computers & Internet
I get ERR: DOMAIN everytime I try to inverse a matrix
  1. First, Press the "MATRX" button
  2. Next, enter a matrix into the calculator. To enter a matrix, press the arrow that points to the right two times when the cursor highlights letter "A." This moves the top cursor to "Edit." Press "Enter" to select the "Edit" option.
  3. Next,, enter the matrix's numbers into the matrix on the calculator. Press "Enter" to move the cursor over one column. Press a button that has a dash symbol within parenthesis [( - )] to move down one row. Repeat the steps until the matrix is completed.
  4. Next, Press "2nd" then "Mode" to go back to the home screen. Press "MATRX" to enter the matrix screen again.
  5. Finally, press "Enter" when the cursor highlights matrix "A" then press "[x^ -1]." Your screen should read "[A]^ -1." Press "Enter" again to display the inverse matrix.
    I got this information from eHow.com
Dec 07, 2010 | Texas Instruments TI-83 Plus Calculator
How to set the decimal place to 3 places on a casio fx 300ms calculator
Decimal Point and Separator Symbols
You can use the display setup (Disp) screen to specify the symbols you want for the decimal point and 3-digit separator.
• To change the decimal point and separator symbol setting, press the MODE key a number of times until you reach the setup screen shown below.
Display the selection screen. (Disp) 1.
Press the number key ( 1 or 2) that corresponds to the setting you want to use.
1(Dot): Period decimal point, comma separator
2(Comma): Comma decimal point, period separator
Nov 27, 2010 | Casio FX-300MS Calculator
Symbol LS 9100 does not transmit data
after scanning the defaults barcode you just scan the "Enable LS 9100 Communication" on this manual on the link above.https://docs.symbol.com/manuals/1536503c.pdf
May 11, 2010 | Symbol LS9100 Hands Free
Aspect ratio changing on ATI radeon hd2400 pro
My wifes DELL has a F key with a blue icon that does that
take a look at the BLUE symbols and see if there is one showing a rectangle with either blue bars on each side or similar
When she presses it the screen changes to a 4:3 aspect with black bars on each side
Jul 03, 2008 | Computers & Internet
Hanging symbol
Try pressing the reset button just above the [1] and [2] buttons.
Regards
Philip
Jun 09, 2008 | Sony CDX-MP40 CD Player
Toshiba Satellite M40-S417TD Notebook Logo
42 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
