Toshiba 56HM195 56 in. HDTV Television
Problem for Toshiba 56HM195 56 in. HDTV Television
Vertical line in middle of screen.
By nghia_nguyen on Nov 09, 2009
Half screen is ok. The right half shows color washou
All indications point to Light Engine
But what about a cold solder joint in this subsystem
Solution #1
posted on Nov 10, 2009
Not Rated)
jeffharris42
Rank: Wiz  Toshiba Televisions & Videos  Expert
Rating: 80%, 20 votes
no the light engine is fine. it is the digital signal processing to the engine. suggest local service center
Comments:
Nov 10, 2009
- no the light engine is fine. it is the digital signal processing to the engine. suggest local service center
Was this helpful?
Yes
No
Popular Solutions for Toshiba 56HM195 56 in. HDTV
Questions and Unsolved Problems for Toshiba 56HM195 56 in. HDTV
Do you recommend Toshiba 56HM195 56 in. HDTV Television?
Answer
Answer
red ghosting around pictures when watching tv. red washout convergence
Answer
Out of the blue, I turned on my tv and it had flickering horizontal lines across the bottom of the... (More)
Answer
I own a Toshiba 56HM195 and have replaced the bulb once (about a year ago). I have owned the set... (More)
Answer
Toshiba 56hm195 HD TV. Buzzing sound started a long time ago. Comes on w/power and shuts off after... (More)
Answer
I just want to know how to clean the mirror on the back of my Toshiba 56hm195 DLP? How to take the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 56HM195 56 in. HDTV...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 727
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
