Question about Sony Playstation 3 (PS3) Console
Playstation 3 I have a playstation 3 80GB. I can not get full digital sound from the units optical output when playing DVD's or Blue Ray disks. Have switched, on the menu, to bitstream output, but the unit only puts out PCM sound (not 5.1 or better) Any thoughts?
  • 109 Answers
First of all, Linear PCM is the best option to choose. PCM (Pulse Code Modulation) is a format for uncompressed raw audio data.
Some 5.1 sets have Dolby ProLogic II for example. The raw PCM output gets spread at your speakers dynamically. Meaning the decoder of your set interprets it the way it thinks is best. For example, if it gets a high frequency tone, it sends it to the center speakers as for human voice has a very high frequency. The center speaker is meant for dialogs.
But when you choose a compressed, encoded format such as Dolby or DTS the channel devidance is already mixed for you for optimal theatre experience.
When you choose DTS or Dolby in the menu of your Blu-ray Disc it will originally output a raw PCM audio stream. The decoder knows how to decode the DTS data out of it when you use the DTS audio track from the movie. The same goes for Dolby. Some movies can output pure PCM, but then most sets use ProLogic II to devide it over the speakers.
It's kinda hard to explain how it works, bottom line is.. there's nothing wrong.
I hope it makes sense to you and your question is answered.
Posted on Jan 23, 2008
Yamaha RX-V595 Receiver will play Dolby Digital 3/2.1 audio Blu-Ray disc with player set to bitstream but will not play DTS-HD 3/2.1 unless output is set to PCM. Is this an issue with the Yamaha Recei
The optical connection (SPDIF) doesn't have enough bandwidth to transfer DTS-HD audio. To use DTS-HD, you must connect the blue-ray player and receiver via HDMI cable.
Each DTS-HD audio track on blue-ray includes also "normal" DTS audio, which is probably used when you select PCM. Player decodes it and sends decoded (non-HD) audio via optical cable to receiver.
Nov 17, 2014 | Yamaha RX-V595 Receiver
Won't load blue ray game
The blue-ray inside your ps3 could be dead. I suggest try playing a DVD-Movie. If this doesn't work than it is dead. To replace it you would either need to call Sony or open the ps3 (This will void your warranty), locate the blue-ray, and find out the model and look in ebay to replace it.
May 03, 2011 | Sony PlayStation® 3 (80GB) Console
Different Audio output between DVD and Blu-Ray DVD
The issue is that not all videos use DTS. Look at the videos that you are trying to play do they support DTS if so make sure that you are selecting the DTS track in the audio setup.
In regards to your receiver if it does not support Dolby Digital then you might want to look at upgrading to a receiver that supports Dolby Digital and DTS if you want true surround on all your videos.
Let me know if you have any more problems or questions
May 12, 2010 | Sony PlayStation® 3 (60 GB) Console
Ps3 wont play blu-ray but will play dvd
ps3 drive and blu ray drive inside of your ps3 went out. try cleaning them and if that doesn't work replace them or send it to sony.
Dec 15, 2009 | Sony Playstation 3 (PS3) Console
Sony palystation 3 80g only plays DVDs and sony playstation 2 gam
You need to replace the blu-ray laser. It's a VERY common problem. It's due to a factory defect with the laser.
Most 80GB models use laser model KES-400A or KES-400AAA.
You can either contact Sony for repair 1-800-345-SONY.
They charge $150 or you can go the DIY route for under $100.
May 13, 2009 | Sony PlayStation® 3 (80GB) Console
PS3 80g only plays DVDs and PS2 games .... help
The reason why DVDS still work and the blu-rays don't is because it's a three part laser. dvd / cd / blu-ray.
The blu-ray portion almost always goes out first.
Getting a digital output from a Blue Ray Player optical out
Check the audio settings in the blue ray audio menu.
Jun 19, 2017 | Sony STR-DE685 Receiver
My playstation 3 will not play any blue ray dics at all
This answer courtesy of Sony USA support.
In the Settings menu
BD/DVD-->HDMI 1080p 24mhz
This will be set to 'Automatic'...change it to 'Off'
Now try to play your Blue Ray disk. It should work.
I got this from answerbag after doing a search for you
Hope it helps
Oct 28, 2008 | Sony Playstation 3 (PS3) Console
Playstation sound thru bose system
you have a few options. Does the bose accept optical input.
the easiest is for you to use component out and take the 3 video outputs to tv and the 2 phono to the sound.
Apr 01, 2008 | Toshiba SD-1200 DVD Player
Hooking up a sony playstation 3 with digital optical cable
Here's one solution, if you have an audio output from your tv, you can go from the audio output on your tv to the audio input on your receiver that way anything that is playing on your tv for example, playstation 3, dvd player etc. Anything playing on your tv will have audio on your onkyo home theater system. The other thing I would try if you want to hook ps3 directly to receiver is go to your connection settings on your ps3 menu and change your connection method to digital optical cable.
Dec 27, 2007 | Onkyo HT-S790S System
Sony Playstation 3 (PS3) Console Logo
104 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
