I have two Philips PTV. Model#50P8341A when powered up...The power button will flash 5 times pause, flash 5 times pause etc. The other Model#55P8341 when powered up will flash 4 times and pause, flash 4 times and pause etc. What is the code for the flashes and the board that needs worked?
Comments:
Nov 16, 2009
- I learned five flashes is not a repair code. Four flashes indicate problem with 5 volt regulation and two flashes can indicate replacement of the ssb!
Near the top of the tv the objects are double exposed with in blue and yellow color.At the top of...
(More)
Near the top of the tv the objects are double exposed with in blue and yellow color.At the top of the tv in a light color you can see a faint color of yellow and blue that sort of swoops down like a curtain.
TV doesn't respond to Remote. It ignores the commands given and then shuts down... then the Timer...
(More)
TV doesn't respond to Remote. It ignores the commands given and then shuts down... then the Timer Light blinks until I unplug the TV.
