Question about Cooktops
Repair a stove
I would like to wire a 4 plate( solid) stove using rotary switches.
    Master:
  • 619 Answers
Individual wirings
Posted on Jan 07, 2008
After using the stove top and all the valves are shut, the igniter continues to click. Not sure which particular one, but I presume the right front, which is the most common used on the stove and the last...
One of the switches that turn on the spark when the burner is turned on has became stuck so even when the burner is turned off it still thinks its turned on. It very well could be the one for teh right front burner or any of the other 3 switches.
Depending on your mechanical ability its not too hard to figure out which one it is. What ya need to do is remove the panel over the burner valves so ya can get to the switches which slip over the stem of the burner valves and remove them in the off position and use a meter set to measure continuity and check each of the 4 switches when in the off position and see which one has a circuit (continuity) when off..when you figure which one has continuity when off that will be the one that is causing the stove to spark when off. Be sure to check all 4 since more than 1 could be bad.
BEFORE ATTEMPTING TO DO THAT AND CHECK WHICH SWITCH IS BAD BE SURE TO DISCONNECT THE POWER TO THE STOVE
GENE
Sep 16, 2011 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
The electric ignition on my GE stove top continues to click wheb\n the knob is in the off position
The problem is one(or more) of the 4 switches that turn on the spark when that burner is turned on is shorted and stays closed (on) all the time.To determine which one it is the front face has to be removed,with THE POWER OFF a meter set to low ohms rating is used to check each switch by removing the wires to it and see which one has continunity (ZERO OHMS) when its off and that switch that slips on the burner valve shaft is the bad switch(s) and needs to be replaced to keep it from sparking all the time.
I hope this helps you to repair your cooktop,
Gene
Aug 07, 2011 | GE Cooktops
I need the wiring diagram and plug/receptacle specs for kenmore electric cooktp 42732
I believe that if you look on the name plate for the unit , it says that you will need a 30 amp, 220 volt supply circuit . This would be a two pole , 30 amp breaker , a run of # 10-3 cable with ground, and a junction box at the stove top location to make the splices. If you are going to use a plug connection, then a 30 amp 4 wire dryer outlet will give you the connection you need .
Apr 07, 2010 | Kenmore 30 in.42731 / 42739 / 42734 /...
Stove plates have three settings. High, med, low.
60 years old . quite possibly not worth fixing .
Mar 05, 2017 | GE Cooktops
All 4 ignators are spaking with the contrtols on off position on my GE JGP328 cook top
It's the Switch Harness. Do not remove the stove and disconnect it from the gas. Turn the gas off under the stove. Take off the: knobs and the plate; burners; hxw screws. Pull burners out and disconnect igniter burners. Lift the top of the oven off. The Switch Harness is on the right, under where the knobs are located. Replace the Switch Harnes.
Mar 30, 2009 | GE 30 in. JGP328 Gas Cooktop
Stove not working
hi gud day.check the wiring inside the unit i think the coz of not working is in the wiring,mealting the wire,unscrew all the screw u see at the top of the unit to open.tnx
Jan 31, 2009 | Cooktops
Kenmore gas stove top switch harness replacement instructions
for the 4 burner if u not use coz of no igniter,use matches or lighter every time to use,if not turn the burner remove the knob & try to use hammer slowly at the top of the gas valve mostly the problem is stockcup,use oil b4 u try to turn.for the harness wire call the contact service center to buy a harness wire to replace the parts,but it so easily to replace the wire try to open the unit to see the wire size,color then gi to hardware to buy a wire same as in ur unit.tnx gerbee
Jan 27, 2009 | Dacor Preference SGM466 Gas Cooktop
Jenn air electric range wiring diagram
In a normal house, black and red are the hot wires and are wired to a circuit breaker or fuse at the panel box. White goes to the ground bar. Sometimes the white(neutral) is seperated from the ground. Sometimes they can be connected together. At the fuse box they both go to the silver ground bar. If you are attaching a cord and plug purchase one to match the outlet you have. Usually at the terminal block the hot wires are on the outside. Neutral in the middle. At the terminal block there is a metal strap or wire going from the center terminal to the frame of the stove. If the cord you have is just 3 wires leave it. If the cord you have uses 4 wires remove the strap and connect it seperately to the green or ground wire on the cord.
Jul 02, 2008 | Jenn-Air JED8230 Electric Cooktop
Cooktops Logo
229 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
