Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer
Problem for Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric...
Model number 110-85866-400. Will not turn on
By vw5460 on Nov 09, 2009
model number 110-85866-400. The lights for check lint and control locked stay on. Lint system is clean and the drier will still not work. What could be the problem, I took apart the top panels and cleaned up the mother boards but still nothing, before the drier went out all the lights were flashing and it was beeping then just died.
Solution #1
posted on Nov 09, 2009
Not Rated)
salde386
Rank: Guru  Kenmore Washers & Dryers  Expert
Rating: 94%, 57 votes
unplug dryer,you have to take bottom panel off,take out lint filter and then remove the duct that that lint filter goes into,you'll see it on left side when you remove the bottom panel,if it died you could have blown the thermal fuse part number 3392519,you will find this on the right top side of the blower wheel housing it's white and has two wires going to it,pull one wire off and check it with a meter,also go outside and check the flapper were it vents outside,that could be blocked,i blow the vent line out with a leaf blower if it's a long run.if you're having lint problems that should take care of it,also if you have a shop vac,put it on blow and blow off the motor,and you can blow all the dust that' in the back forward so you don't have to remove the drum.hope this helps
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 7.0 cu. ft. HE4
Questions and Unsolved Problems for Kenmore Elite 7.0 cu. ft. HE4
Do you recommend Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus Electric Dryer?
Answer
Answer
did diagnostics on kenmore elite gas dryer-- code 59 shows up--what is this?
Answer
i have a kenmore he4 about 5 yrs..my dryer light burned out and dryer would not work at all... i... (More)
Answer
Kenmore Elite shuts down and gives an F2 fault code. Usually in spin cycle.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Dryers Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
