Question about Hitachi 43UWX10B 43" Rear Projection Television
T.v turns off while watching
The t.v. will turn off while watching or won't turn on at all.But when I hit the side of the t.v. it will come back on.Any help will be appreciated thanks.
    Genius:
  • 1,153 Answers
Yes, it could be as simple as a cable inside coming from the auto link and 4 event timer. This needs to be redress from front control panel away from Blue CRT-yoke HV lead. For more info ctechnicians.com
Posted on Jan 06, 2008
How to set time on a Lorus watch Z001 X001
Digital
Press the button on the bottom left-hand side of the watch to change between the modes on the watch.
Press and hold the button on the bottom left-hand side of the watch for two seconds until the seconds begin to flash.
Press the button on the top right-hand side of the watch to set the seconds to "00" and press again to set.
Press the button on the top right-hand side of the watch again until the hours flash. Press the button on the bottom right-hand side of the watch to change the hour display. Press the button on the top right-hand side of the watch to set.
Repeat step 4 to set the year, month and day on the watch.
Analog
Pull the small knob on the right-hand side of the watch, also known as the crown, out one click.
Turn the crown until the previous day's date is displayed.
Pull the crown out one more click. Turn until five minutes ahead of the correct time and then turn back to the correct time.
Push the crown back to the side of the watch. The watch is now set.
Mar 31, 2018 | Lorus Watches
After charging phone,, it will not turn on...a little RED light is flashing..green normally
Hi Anonymous, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that might help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
Apr 29, 2016 | Cell Phones
I hit a brick, lawnmower won't move help
check for bent crankshaft at blade connection point. do this by removing spark plug and turn the mower on its side with carburator side up, now spin blade by hand and see if it will spin without a wobble. if it does not want to move, something else inside the engine is damaged and probably not worth fixing. if the blade does not spin true, it is a bent crank and might be able to be straightened by a mechanically inclined person without further damage to the motor. also check to see if the piston is moving while spinning the blade if it will turn at all. R
Sep 02, 2012 | Mtd 22" Yard Machine Push Mower
Unplugged tv for storm, plugged it back in now it trys to turn on but won't
plug in a bed side light and see is it working and if it is not then the storm has damaged the tramsformer supplying your house
Aug 08, 2012 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Washer wont cycle
Number 11 is your lid switch. It is very easy to repair. To test it watch the video.
Older models would wash with the lid open but not spin. This later model washer won't wash or spin with the lid open so I suspect you have a broken lid switch. IF that turns out not to be the case then I would next check the motor start capacitor. When these fail the motor won't work at all.
On your machine you gotta have a long skinny screwdriver . On the back side of the washer you back out a screw on each side and then she pops up.
I gotta whole page of stuff on these washers HERE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 01, 2011 | Estate TAWS850PQ
My 2001 Cadillac deville was hit i'n the front driver side and during the accident i moved my car out the road and parked it to talk to guy who hit me so I turned off my car and got out and later when...
Hello. There is automatic fuel shut off switch. When the car is in an accident like you were. The switch trip and turn off the fuel. There should be a red button in the trunk on one of the side panels. If not, call the dealership and ask them were the auto fuel shut off button is located. Also, it might in your vehicle owner manual. GB...stewbison
Aug 20, 2011 | 2001 Cadillac DeVille
I cannot replace the back of a timex 1854 watch. I replaced the battery but the back won't click on
I used a four inch "C" clamp and a large washer about diameter of back, to get my Timex back snapped back on. Place the watch face side down on a flat surface cushioning the crystal with soft rubbery material like shelf liner or anti skid material used under rugs (the kind used to also line tool chest drawers - black). Place the washer between the watch back plate and the "C" clamp screw plate. Align the back plate of the Timex as evenly on watch as possible while gradually tightening the "C" clamp. Keep turning down the "C" clamp ever so slowly until you hear the plate snap back on.
Jun 28, 2011 | Watches
I have locked the steering wheel, how do I unlock it. Now the car is immobilized and I can't start the engine
You may have to use a little muscle here. When this happens, turning you steering wheel to the left usually will release the ignition lock cylinder so tha you can turn the key. Make sure you hold the steering wheel once you have turned it. Keep in mind, it won't turn very far. One side you turn to will feel like it hit something solid, the other side you turn to will be the unlock side.
So
Turn steering wheel and hold until you are able to turn the key. It will take a bit of effort on your part, but that should get it back going.
Jun 21, 2011 | 2009 Volkswagen Tiguan
Lost remote
lost remote, can not switch imput
Nov 01, 2007 | Televison & Video
Hitachi 43UWX10B 43" Rear Projection Television Logo
35 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
