Thanks for using FixYa.
Dishwasher not draining properly or not draining at all issues can arise due
to different reasons. Usually, these issues are related to kinked hoses,
knocked out disposer unit (if connected with the dishwasher drain hose) &
clogged drain pump & filter.
Also note that dishwashers do not
drain completely after a finished cycle and this is normal. Dishwashers are
designed to leave some water in the unit to ensure that the heating element
doesn’t overheat. If you suddenly begin to experience a large amount of water
being retained in your dishwasher, you have a problem. Some of the most common
reasons include that the drain hose isn’t working properly, the drain pump
isn’t working correctly, or possibly there is a plumbing problem in your home’s
drain lines.
First check whether the drain is
not clogged or blocked and the line is not kinked. Check all the hoses for
blockages & also clean the air gap. Has the disposer been replaced
recently? If so, chances are the knockout is still in place. Simply remove the
drain hose from the disposer, and knock out the plug. If the disposer has not
been replaced, try removing the drain hose from the disposer and use a wet-dry
vacuum (prepared for water, of course) to **** any water (and hopefully anything
else) from the drain line. Then reconnect the hose, and test the unit. If you
have checked the air gap and the drain hose and can’t locate the problem, then
it is an issue with the drain pump of the dishwasher.
Please do rate the solution and revert for further
assistance.
Thanks
Rylee
Was this helpful?
Yes
No
Popular Solutions for KitchenAid KUDC25CH Dishwasher
I have a GE Quiet Power III dishwashwer that has completely lost power. Pushing the buttons does...
(More)
I have a GE Quiet Power III dishwashwer that has completely lost power. Pushing the buttons does nothing. Am I going to have to replace the whole thing?
Kitchenaid dishwasher still leaks even after I replaced all the gaskets and seals. I replaced the...
(More)
Kitchenaid dishwasher still leaks even after I replaced all the gaskets and seals. I replaced the bottom door seal and the tub gasket/seal. The dishwasher still leaks from the bottom of the door. Should I try putting silicone on the bottom door seal?
Door latch will not work - broken. Was working fine. closed the door to do a load, and now it will...
(More)
Door latch will not work - broken. Was working fine. closed the door to do a load, and now it will not open. The Door is closed and I am unable to open.
I have tried combinations of buttons and time to try to get this to reset, with no success....I will...
(More)
I have tried combinations of buttons and time to try to get this to reset, with no success....I will try a power off reset next.
