the problem is that the menu screen keeps appearing ? You hit the menu button and pictures appears for a few seconds and back to the menu screen. What do I do?
the tv shows no picture but our stereo system(seperate from the tv) is working. the usually green...
(More)
the tv shows no picture but our stereo system(seperate from the tv) is working. the usually green light in the bottom left hand corner is now red and flashes
Philips 42pf4630a plasma repeat problem... high pitch audio static from left speaker was repaired...
(More)
Philips 42pf4630a plasma repeat problem... high pitch audio static from left speaker was repaired during warranty (audio board), 2 years later same problem, but now left speaker only outputs high pitch static. Using balance menu I cannot adjust sound away from left speaker.
tv has intermittent horizonal sections that are digitized and then in the middle of the screen one...
(More)
tv has intermittent horizonal sections that are digitized and then in the middle of the screen one section you can see perfectly
