Sharp Aquos LC-42D62U 42 in. HDTV LCD Television
Problem for Sharp Aquos LC-42D62U 42 in. HDTV LCD Television
Emerson 32 inch lcd tv two years old has lines
By spikesurge83 on Nov 09, 2009
emerson 32 inch lcd tv two years old has lines running vertically in different areas of the screen top to bottom. What would cause this? The are red green and blue. Is it a known defect?
Best Solution
posted on Nov 09, 2009
Very Helpful)
mikeoldfield
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 40 votes
I don't know anything of this particular TV, but what you describe is generally a known problem in LCD displays.
it's caused by one of two things - either parts of the LCD film thin film for the vertical lines detatching from the board it is glued on or certain micro controllers that are also glued on the LCD film starting to get burned bit by bit. In both cases, the whole vertical line responsible for one of the three colors that a single pixel consist off get dead and depending on how they get dead they get either all open or all closed, respectively completely turning on or shutting off the particular color.
It is most commonly the first case, but whichever of the two it is, there's no known cure for it within reasonable cost.
I've experimented a few times and was able to press the film to the board by using firm objects and fastening the display case, but it would often cause more harm than it brings and even more often it would just not hold reliably. Overall I do not recommend experimenting with it it unless you have lots of time on your hands and you're ready to face an evern worse damage.
In a very rare cases it might also be the tcon also known as LCD controller...but from what you describe it's hardly it. It's worth trying, but if I had to take a guess I'd rather rule it out - it sounds like the LCD.
And the bottom line is you just have to face it - you likely need a new TV. If there's some chance for me to be wrong, try the tcon board at the back first. Then just sold the TV on eBay or CL for whoever gives you most and apply the money towards the new purchase.
Don't kill me, I'm just the messenger :-)
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Sharp Aquos LC-42D62U 42 in.
Questions and Unsolved Problems for Sharp Aquos LC-42D62U 42 in.
Do you recommend Sharp Aquos LC-42D62U 42 in. HDTV LCD Television?
Answer
Answer
My LCD TV has a small break on the screen. Any recommedations on where I can get it fixed for cheap?
Answer
I have a panasonic flat screen that just lost the red from the color. Everything is green and blue.... (More)
Answer
Can't adjust volume on Sharp LC-42D62U TV using remote or the control on TV. Also can't access menu... (More)
Answer
My Sharp Aquos LC-42D62U 42 in. HDTV LCD which was bumped into pretty hard and the inside screen on... (More)
Answer
i have a sharp aquios 52 lcd tv...my problem is the tv will not turn on...power light turns on then... (More)
Describe your Flat Panel Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Flat Panel... Experts
Top TV Repairmen
in Beverly Hills, CA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
close
Add to My Products
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
Step 1: Select a category & subcategory
Appliances Cameras Cars Computers Electronics Home Audio TV & Videos Tools
Appliances Cameras Cars Computers Electronics Home Audio TV & Video Tools
Step 2: Select a product and click on add
I can't find my product
select
Cancel
close
Success!
Add another product
Close
close
Save This Product
Enter your email address
We will not share your email. Privacy Policy
I agree to the FixYa Terms of Use
Send to friends
Your name:
Your email:
Your friends email addresses: (e.g. Julie@email.com)
(Separate email adresses with commas)
Message:
Cancel
