New pressure washer runs starts and runs for 30-45 minutes with no problems then dies and will not restart. Once it cools for a few minutes it will restart but will die again quickly. If it is allowed to sit for 30+ minutes it will run for another half hour but then dies again. Changed oil, gas, checked all obvious areas. Any suggestions?
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal...
(More)
Where can I get seal rings and o rings for my pressure washer pump without buying an entire seal kit? Faip 193490.
Cannot start Homelite 7 HP EX21 gas pressure washer. Not sure how to set the primer lever? Forgot to...
(More)
Cannot start Homelite 7 HP EX21 gas pressure washer. Not sure how to set the primer lever? Forgot to turn on switch. Turned on switch, now cord is tight, will not pull?
When the power switch is first turned on it makes a repeating loud noise until the water trigger is...
(More)
When the power switch is first turned on it makes a repeating loud noise until the water trigger is pressed and when the trigger is released the same noise starts again
karcher K2.91 will not switch on unless you start on low pressure adjustable detergent lance had...
(More)
karcher K2.91 will not switch on unless you start on low pressure adjustable detergent lance had warranty claim for oil leak Can you tell me how mutch oil should be in pump ?
