Television my tv remote is not working properly....sometime it works and sometimes it doesnt.......... if ter any way to check it
  • Anonymous Feb 11, 2008
    Remote worked on and off and then stopped completely. Bought a new one just to be sure but still no joy. Works the DVD player just fine but wont do anything to the TV. REALLY annoying...
  • sawbladedave Mar 06, 2008
    my toshiba 32a41 had no original remote so i bought a new universal remote (radio shack 15-1992) and it worked great but when i changed the batteries i cant get it to reprogram.i even tried the remote on 4 other tvs and no problems,i even bought a nother new ge remote and that one wont work the 32a41 but works all others
    Novelist:
    Champion:
  • 211 Answers
Radio Shack sells an ir strip for a few dollars. When you push a button on the remote, with the remote aimed at the is sensor strip, you see a redish light if the remote is working. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
    Guru:
  • 1,894 Answers
See if led is working by using ur mobile cam
My tv doesnt work if i transfer to other channel or to volume, i think it has been lock. waht should i do?
Try the local control buttons on your TV. This should work at least.
Sometimes, people forget that batteries in the remote get empty....
Oct 13, 2014 | Televison & Video
How to fix a tv remote for samsung tv
Check the batteries sometimes they are good but not fitted properly.
Roll the batteries that sometimes works or check the batery terminals are not corroded?
Feb 09, 2014 | Televison & Video
Power button on my rca tv wont turn on sometimes
A number of possible reasons for this---failing part in set or even bad connections on main board in the set----model listed is prone to going dead with high pitched squeel etc.
Oct 31, 2012 | RCA TruFlat 27F520T 27" TV
Menu keeps flashing remote control wont work, cant change channel or volume.when i hold down channel up andmess with remote sometimes it changes channel. channel down button is only one that doesnt change...
U have 2 situations:
1st U have a tv Key stucked or internal control board defective.
2nd U have a broken tv remote control.
Note: Check for stuck pressed keys on TV, if not send to repair shop, for checkup.
Nov 29, 2009 | Insignia IS-LCDTV32 32 in. Television
Remote doesnt seem to work on all the button can it be replaced
Did you check the battery of the remote?
Remote is jamp. Take the battery out and put it back. It will help sometime.
Did you notice the light in front of the TV response to remote control whenever you press? If yes, the remote works fine - problem comes from your TV.
Aug 12, 2009 | Televison & Video
All of a sudden my TV remotes do not work properly
Since you said that the remote that originally came with the television does not work either, it's most likely a problem with the IR sensor in your television.
To make sure that something more important with the television did not fail, the next time this occurs, walk up to the television and attempt to manually change the options using its controls.
Nov 19, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Volume controls dont work when using remote
I would start by trying other codes on the universal remote. Sometimes codes will only work part of the remote such as the numbers or channels but not volume. Your motorola cable remote sounds like it may only need a good cleaning. sometimes when you take remotes apart it will look like somthing got spilt in it. I would start there first.
Mar 17, 2008 | Sanyo DS27910 27" TV
Remote Problems
Put new batteries in and try again. Sometimes the IR sender may also not be working properly due to a loose connection.
I would also suggest to open the remote and clean the contacts using alcohol. Rub the contacts on the key pad and remote gently.
Hope this works.
Feb 26, 2008 | Toshiba 36A61 36" TV
Intermittant remote
yes they do go bad. try cleaning the inside of the remote and check for a bad solder connection with-in the remote. the key pad can get dirty from your handling maybe a good cleaning but do not scrub it just lightly touch the pad with cue tip and alcohol
Dec 12, 2006 | Toshiba CZ36V61 TV
Televison & Video Logo
152 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
