Home | Mitsubishi | WS-55809 55 in. Rear Projection Television | I have a 56
Mitsubishi WS-55809 55 in. Rear Projection Television
Problem for Mitsubishi WS-55809 55 in. Rear Projection Television
I have a 56
By shemy74 on Nov 09, 2009
I have a 56" rca big screen tv,we were just wantcing it and all of a sudden the picture went weird and when you turn it on there are colored lines at the top of the screen and then the picture comes on like its in 3d double
Solution #1
posted on Nov 09, 2009
Not Rated)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 855 votes
WS-55809 uses two of the STK-392-570 convergence chips-----usually it is not a soldering problem--I have seen dozens of these sets that use this chip--some of the chips before they totally fail do this--convergence comes and goes--I have also seen several when I unsoldered them that the pins literally fell out of the chips--
I HAVE START TO FINISH, STEP BY STEP INSTRUCTIONS FOR THIS REPAIR IN THIS SET--if you can solder well and are handy--you can buy a pair of the chips on Ebay for less than 13 dollars plus shipping.
I cannot give you my email address but..........
I have also photos of a few things you need to look at if you do this repair----The instructions tell you how to do the repair and also tell you EVERYTHING you will need to do it.
If you have some idea of how I can get the instructions to you other than here let me know--
Take my word for it---if convergence is jumping in or out you need to replace both chips and the set will not have this problem again for 5-8 years--lifespan on these parts.
IF THIS information has helped you, rate this solution as I do this here for free.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WS-55809 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55809 55 in.
Do you recommend Mitsubishi WS-55809 55 in. Rear Projection Television?
Answer
Answer
Trying to figure out to find my television code for media center Mitsuibishi Medallion CRT
Answer
when purchasing replacement convergence IC STK392-570 are they specific to the TV brand, I see... (More)
Answer
I turned on my Mitsubishi ws 55 in TV and was going to play my PS3 when I received no picture. This... (More)
Answer
as soon as i turn on the tv it turns off it clicks on then 2 seconds later it clicks off. i self... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WS-55809 55 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
