Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Covergence replaced ic's
First off thank you for your time!
I have a nice sony kp51ws510 from a guy at work who said the covergence was out. It was just the blue which I have delt with before on another t.v. I knew it was the ic's so I replaced them right away (I used generic stk392-560). I used what I thought was a nice amount of artic silver thermal compund for the heatsinks and my soldering was nice and neat. The set worked great for about a month or two. Just last nite I was hanging a speaker above the t.v. ( didn't slam it or anything) and when I came down and looked at it, I noticed all of the colors are out now and bowing or concaving in the upper left corner. It is BAD! Could this be bad ic's again or somthing else? Maybe because they were generic?
Any help would be greatly praised!!
Thanks again,
Josh
  • angrytaco Jan 12, 2008
    Thank you sir,
    Unfortunatly I already replaced the ic's because I had another thread that got an answer before you. I replaced them and it is doing the same thing. Does this mean that I have to replace the resistors, pica fuses and the ic's for the third time? I am hoping that I can just do the resistors and fuses. I only had the set on for a second to notice the picture.
    Thank you very much again!
    -Josh
    Genius:
  • 1,153 Answers
Well Josh, I am here to tell you, you are right. This is the problem you have when you replace the STK's and do not replace the return resistors. Atleast one thing you didn't need before were the small pica fuses, but now you might also. So yes you will need the amps again, and by the way this is the first time I am reading where someone used good compound on their IC's, They all need it but you are the first I've read that mentioned it. Hope this helps, and I wouldn't know off hand the resistors location without a schematic.
Posted on Jan 06, 2008
  • Lashawn Robinson Jan 15, 2008
    As a Technician I would, because it could cause some other part to be damaged. But if you don't you would be gambling!
Horizonal is messed up on sony kp51ws510 red and yellow colors
Replace convergence IC STK392-560 and also check 3.15A picofuses. Goodluck! :)
Dec 28, 2009 | Sony KP-46WT510 46" Rear Projection HDTV
Kp51ws510 power problem
Gould, heres your fix, replace both IC`s marked "MCZ3001D" on the top of the chips, they are both located on the "D" board, if your not a tech but you know how to do solder work you can buy the IC`s here 1-800-575-9833,very common fault for your set
Nov 30, 2007 | Sony KP-51WS510 51" Rear Projection...
Have Covergence problem on my Sony KP-51HW40
Actually yes! If you have access to the Professional Service Manual I believe they give you an area or B&W pictures or a very poor stick drawing of the TV Cabinet that shows which boards are which.
The convergence IC's are probably STS surround sound amplifiers and are sandwidched inbetween large heat sinks. There usually are two sets - one for horizontal controls and the other for the Verticle controls.
Blessings,
A/V Media Guy
Nov 22, 2009 | Sony KP-51HW40 51" Rear Projection...
I have a sony projection tv model #KP51WS510 and I was told the convergance amplifier was going out and I was needing info about where it is located so I can change it out. Thanks
convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Oct 24, 2009 | Sony KP-51WS510 51" Rear Projection...
When I try to do the manual converegence on my sony kp51ws510, I cannot get the squares around the + to change to red or blue and consiquently I cannot adjust the convergence. Flash focus works fine but...
You need to replace the convergence IC, They start with STK make sdure you get original stk IC's and not cheap china made or aftermarket parts as they will not lasts long in your set. if you pay less then 15 bucks for your IC that really is no bargain cause it is most likely an aftermarket IC
Aug 14, 2009 | Televison & Video
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Kp51ws510
Replace Both STKs ICs big black ics .
Sep 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony kp51ws510 convergance problem
You need two convergence ICs they are both STK392-560 you can get replacementICs at the following link and they provide free instructions with pictures and free tech support to help you with the replacement proceedure.
http://servicemanuals.vstore.ca/
Jul 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Convergence
Hi Josh,
Was the stk392-560 a replacement for a 110? I have found that, even though the manufactures seem to recommend to replace the original ic's with a 560, sometimes the 560 don't work quite right, or don't hold up long. Also I'll mention, that probably 80% of the big screen projection problem I get in my shop are the convergance chip, so I am to the opion that there is not a good solution for fixing the problem long term. ( In my opion, the manufactors need to invent something better ). Spend the 50 tp 100 dollars again and replace both chips again, but I recommend the originals, and use ample heat sink compound ( these chips run real hot ). Also some of the manufactors have started installing cooling fans ( suggestion ). A omputer CPU fan works quite well. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
64 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
