CLEAR CMOS Hi Can you please show me where the cmos battery is sited on my Rock Extreme SL ( Clevo M590K ) and also where any switches are to clear the cmos. Thanyou Tony
  • 243 Answers
First switch off at wall and remove power leads. The push on button to discharge capacitors on board.
 The jumper will be located near the bios battery and chip usually at the bottom right of motherboard. Move the jumper to the clear position and leave for a few mins. Then put back into normal postition and start pc up.
If that fails to clear it then repeat but remove the battery from the motherboard too and wait longer.
Hope that sorts it for you?
Posted on Jan 06, 2008
Clear CMOS Jumper JBAT
Unplug the power cord and remove the RTC battery,quarter size watch type battery, for 10 min's.Put the battery back in and power it up.that should clear the cmos
May 19, 2014 | Asrock 775S61 Motherboard
How do I find and replace cmos battery on Clevo M762T/Sager NP7660 laptop notebook?
Your laptop CMOS battery is CR2032 and instead of writing the instructions on how to replace the CMOS battery I am posting the link where it has been illustrated with images/pictures.
I hope this helps, please let me know if you have any further questions.
Best regards,
Amar Sondhi
Nov 20, 2013 | ASUS D1 500 (ap d1500) Barebone
How can i reset the cmos in my ms200 all in one computer?? it shows that my hasrd drive is not working, and it is really working in other computer
To reset the CMOS the easiest way is, remove the motherboard battery for ten minute then install it again. It will clear the CMOS. Then reset the CMOS/BIOS setup, date/ time etc. Another way to clear CMOS is, reset the CMOS Jumper in motherboard.
To detect your hard drive you can try to check by change the hard drive cables. Change the port in motherboard. Check the BIOS setup and reset it if need.
Jul 06, 2011 | HP Pavilion AllinOne MS214 185" Desktop PC...
Clearing cmos password or cmos clear jumpoer location.... where can i find?
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using Software:
I have found that using Dogber1's Dell Password generator is a great solution to this problem. It is free and takes approximately 10 seconds to download from his site.
B. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
Good luck
Please Rate FIXYA
Mar 29, 2011 | Dell Inspiron 1300 Notebook
How to clear cmos in asus a7n266 mb
I had similar mobo and this is what the Asus technician told me. Take out the round battery in your motherboard and flip it around and put it back into the battery slot.(it sounds weird but that is what he said) Hold it there for 20seconds and then put back in the right way it was.
Your cmos should be cleared now. Make sure your pc is switched off when doing this.
Feb 08, 2011 | ASUS NVIDIA nForce Chipset A7N266-VM...
I need to reset password on my Acer 4230, and I can't find the cmos battery to remove
The CMOS battery looks like a small circular disc
Just remove the connector hold for 30 seconds and plug it back in. Thats all.
Jan 27, 2010 | Acer TravelMate 2300 Notebook
Soltek sl-k8trpro939, error message BIOS not Loaded,
To clear cmos you'll need to remove the cmos battery from the motherboard for about 5-10 seconds then replace. You need your motherboard disk in order to load the bios. If you do not have this disk then you will need to go to the board manufacturer's website & download the bios. Follow the directions they have at the site to make a bootable disk & then boot from this disk. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Soltek SL-KT600-RL Motherboard
Dip switch positions for cmos reset please my hp compaq nx6310 is having passwaord  that i didnt put, so i want to clear the cmos
there is no any dip switch for reseting COMS
if u want to reset coms u need to disconnect u r laptop battery & then disconnect coms battery from motherboared witch under keypad .then get press powre button for 30 sec.for discharge static charge of u r motherboard .after that u connect all this to u r laptop u get reseted COMS
if this information is useful for u please Rate me................
Jun 18, 2008 | HP Compaq nx6310 Notebook
Please help me
Check ASROCK P4i45GV R5.0 User Manual Page 17 -
Note: Check Page 11 for the CLRCMOS0 location on the motherboard. From the picture CLRCMOS0 is number 18. You can locate CLRCMOS0 just below the CMOS Cell Battery.
Turn off the computer and unplug the power cord, then use a jumper cap to short the pins on CLRCMOS0 for 3 seconds. Please remember to remove the jumper cap after clearing the CMOS. If you need to clear the CMOS when you just finish updating the BIOS, you must boot up the system first, and then shut it down before you do the clear-CMOS action.
Mar 22, 2008 | Asrock P4I45GV R5 Motherboard
Computers & Internet Logo
1,161 people viewed this question
David Payne
David Payne
