Home | Frigidaire | (ATF6000ES) Front Load Washer | My washer won't com...
Frigidaire Front Load Washer
Problem for Frigidaire (ATF6000ES) Front Load Washer
My washer won't complete the final spin cycle. It
By mhaines9 on Nov 09, 2009
My washer won't complete the final spin cycle. It goes through the wash and drain OK but won't spin, clothes are soaking wet. I removed the drain pipe and made sure it was not blocked, also removed and checked the other drain pipes, nothing was blocking them. When I set the cycle to "Drain/Spin" some water drains out but the washer does not spin, the indicator lights are "No spin" and "Door Lock." Any ideas?
Best Solution
posted on Nov 09, 2009
Helpful)
mgprice
Rank: Guru
Rating: 96%, 429 votes
Hello, problem here is the spin control board is bad. Remove panel under the door and you can locate the spin control at the rear right of the machine screwed to the floor. Replace it and you will be all set. Mike
Comments:
Nov 11, 2009
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Frigidaire Front Load Washer
Questions and Unsolved Problems for Frigidaire Front Load Washer
Do you recommend Frigidaire (ATF6000ES) Front Load Washer?
Answer
Answer
black rubber in front seal of door seems jammed what do we do
Answer
It goes through part of the cycle but stops before spinning and code A20 comes up. I don't have the... (More)
Answer
model gltf1040ASO the motor will spin for the back and forth cycle but not the spin cycle...makes a... (More)
Answer
how do i rest the computer chip on my frigidaire washing machine?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire Front Load Washer:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14705
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
