Question about Sony KP-51WS510 51" Rear Projection HDTV-Ready Television
Convergence Hello all, I got me a nice sony kp51ws510 from a guy at work who said the covergence was out. It was just the blue which I have delt with before on another t.v. I knew it was the ic's so I replaced them right away (I used generic stk392-560). I used what I thought was a nice amount of artic silver thermal compund for the heatsinks and my soldering was nice and neat. The set worked great for about a month or two. Just last nite I was hanging a speaker above the t.v. ( didn't slam it or anything) and when I came down and looked at it, I noticed all of the colors are out now and bowing or concaving in the upper left corner. It is BAD! Could this be bad ic's again or somthing else? Maybe because they were generic? Any help would be greatly praised!! Thanks a mil guys, Josh
The bowing or concaving in the upper left corner was just caused by the mecnetic field. Keep the speakers away, the pictures should return to normal in a week or two.
Posted on Jan 13, 2008
    Novelist:
    Champion:
  • 211 Answers
Hi Josh,
Was the stk392-560 a replacement for a 110? I have found that, even though the manufactures seem to recommend to replace the original ic's with a 560, sometimes the 560 don't work quite right, or don't hold up long. Also I'll mention, that probably 80% of the big screen projection problem I get in my shop are the convergance chip, so I am to the opion that there is not a good solution for fixing the problem long term. ( In my opion, the manufactors need to invent something better ). Spend the 50 tp 100 dollars again and replace both chips again, but I recommend the originals, and use ample heat sink compound ( these chips run real hot ). Also some of the manufactors have started installing cooling fans ( suggestion ). A omputer CPU fan works quite well. Good Luck
Ed
NC Electronic
Mills, Wyoming
Posted on Jan 06, 2008
My sony has extra blue and yellow in it and any words on it have blue and yellos words under it and to the side
This tv have a problems known as convergence,it dead.The tv convergence board require the 2 STK covergence ICS and some or all it resistors to be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 21, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
IHAVE A COVERGENCE PROBLEM WITH SONY KP-65WS510 THE RED AND BLUE ARE OUT OF SYNC.
Ur tv convergence are dead.U know how to solders?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 01, 2010 | Sony KP-65WS510 65" Rear Projection...
When I try to do the manual converegence on my sony kp51ws510, I cannot get the squares around the + to change to red or blue and consiquently I cannot adjust the convergence. Flash focus works fine but...
You need to replace the convergence IC, They start with STK make sdure you get original stk IC's and not cheap china made or aftermarket parts as they will not lasts long in your set. if you pay less then 15 bucks for your IC that really is no bargain cause it is most likely an aftermarket IC
Aug 14, 2009 | Televison & Video
Sony-kp51ws510 picture turns to a blue hue with flickering colors
hello there this is an easy fix unplug the tv and take the back of the set, once inside the set you will see 3 coloured bulbs and a big mirror in the back theses over time get dusty and dirty and if you smoke it can get really bad you simply just need to clean the bulbs and the mirror with computer screen wipes or some sort of window cleaner be sure not to get everything wet inside this should sort if for you nice and clear again!
Thanks For Using FixYa
Feb 07, 2009 | Sony KP-51WS510 51" Rear Projection...
Arched screen
You have a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in but stationary.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
>>>Solution<<<<
You need to replace the convergence chips and convergence resistors.
Check the site www.TvRepairKits.com
They have put together a kit for your exact model.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc. Everything you need to fix it yourself.
Jan 08, 2009 | Sony KP-51WS510 51" Rear Projection...
My sony KP51WS510 Too blue or red, double exposure
This type of fault is harder to locate since the I cannot see the picture my self.
It could be a convergence problem or G2 problem. Either way U should take to a service center.
I don't think this is just a do it ur self kind of fault
Sorry. I can't be of any more help
Rifaa
Nov 15, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony rear projection convergence
This is a convergence problem that is either bad connections on the convergence ICs or defective ICs. IF you can solder and feel comfortable working inside the set, you can fiox this yourself. Let me know if you wish to attempt the repair and I'll post more details and instructions.
Dan
Nov 06, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Sony KP53S35 blue projector problem
You need to replace both convergence ICs. They are STK392-110 they are located on the g Board on big heat sinks designated as IC809 and IC810. You can get new replacement ICs at the following link and they provide free unstalation instructions with pictures plus free on line tech support. here is the link. If you cant access the site right away try again cause they get super busy in the evening with customers placing orders.
http://servicemanuals.vstore.ca/
Apr 23, 2008 | Sony KP-53S25 53" Rear Projection...
Covergence replaced ic's
Well Josh, I am here to tell you, you are right. This is the problem you have when you replace the STK's and do not replace the return resistors. Atleast one thing you didn't need before were the small pica fuses, but now you might also. So yes you will need the amps again, and by the way this is the first time I am reading where someone used good compound on their IC's, They all need it but you are the first I've read that mentioned it. Hope this helps, and I wouldn't know off hand the resistors location without a schematic.
Jan 06, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 51" Rear Projection HDTV-Ready Television Logo
160 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
