It indicate that your print head may defective probably cause by electrical connection, u can try to unplug the print head and clean the electrical contact part with dry paper and install it back. Make sure the contact part is fix into the holder completely.
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I...
(More)
Hello. My Canon i950 was showing 8 yellow flashes indicating the ink waste tank is getting full. I removed the ink pads in the bottom of the unit. I cleaned them and let them dry before replacing them. I followed the code directions and the yellow light does not blink now, just solid green, but it won't print either. Only error message is, problem with printer. Help Please!
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and...
(More)
Printer: Canon i950. Two problems: The "utility" icon on the computer is grayed out and non-functioning. The larger problem is that when I try to print a black document, it comes out a faded, washed out almost pea-green color. I printed a test page - what should be black is pea-green. As I said, the "utility" icon is grayed out and I can't access that. Any suggestions, hints, solutions, etc.? Thanks! mg
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to...
(More)
Reds are not printing on my canon i950 ink jet printer. (Mac OS X) I have used the utility to perform several cleanings and at least 2 deep cleanings. I used a Q tip with rubbing alcohol to wipe the port where the ink is fed to the nozzle, still no reds. What can I do.
