telescope meade lx200gps, installed bucks gears & no movement in dec during auto align.allignment stops at ""find level. dec moves manually. no broken wires; all connectors good; reloaded software 4.2g, no help
The main board is inside the base. You may have accidentally unplugged a wire to the board while you were installing the gears.
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
No didn't fix problem. Called Pete at Peterson Engineering and he suggested a few things to check but didn't fix problem.Sent scope to Meade repair.
" - vegasshop
i have recently purchased a Science Tech 262 Telescope. i have collimated it and set it all up. i...
(More)
i have recently purchased a Science Tech 262 Telescope. i have collimated it and set it all up. i have tryed all of the four eyepieces in the telescope and can get a good image with just two of them. i cant get any image with the erector eyepiece fitted, it is 1.5x, and i cant get a good image with the 4mm eyepiece fitted either. im trying to view a house chimney stack at around 300mtrs. the image is blurry with the 4mm eyepiece fitted. any help is much appreciated. ****.
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does...
(More)
I HAVE A MICRONTA ELECTRIC POWERED ZOOM TELESCOPE 12X-40X-40mm CAT. NO. 66-203 ----- ELECTRIC DOES NOT WORK WOULD LIKE TO GET IT FIXED IF NOT TOO EXPENSIVE OR PROBLEM SOLVE WHY IT DOESN'T WORK
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or...
(More)
I purchased a bushnell 78-5500 and i don't have a manual and i can't mount it How can i mount it or where i can find a manual online Sorry if you don't understand me i'm french
I would like to find an instruction manual for this telescope. Any ideas where to look?
Want to...
(More)
Want to identify this model, then get manual. All it has is "FIELDVISION TELESCOPES" on the body. Then on the lens it has: MAKSUTOV-CASSEGRAIN TELESCOPE D=90MM F=1200 MM f/13.3 MULTI-COATED OPTICS
