Question about Samsung SyncMaster 205BW LCD Monitor
LCD Monitor blacks in and out for 1-2 seconds
My LCD monitor blacks in and out randomly for 1-2 seconds, then it comes back to normal. One time my power went down and when it came up again, my monitor wouldn't start (i was pushing the power button and it would shut off back). I think that's when the blacking out started. This happenes when I'm at the PC or when i watch tv on it (with an external TV tuner).
The monitor is still under waranty but sometimes it doesn't black out for 1-2 hours in a row, so I can't really take it back to the shop untill i know what could be the problem.
  • 1 more comment
  • keeekeeess Jan 06, 2008
    No, it doesn't have an external transformer, it has a cord just like the computer's. When it blacks out the power button remains blue, like the monitor is running normal. I don't get a 'searching for signal' either.
  • Anonymous Jan 09, 2009
    syncmaster 510n
  • James Stevens Jan 14, 2009
    A friends monitor has the same problem - blue LED turns on for 1-2seconds and then repeats. The monitor image briefly displays. I took the whole thing apart and found that if the CN4 and/or CN6 were plugged in the monitor would continute this power cycling. If I unplugged CN4 and/or CN6 I could get the blue LED to stay on, but still had the display for only 1-2 seconds. With no input ("Samsung test mode") I get the same 1-2 second flash routine. Have also tried VGA and DVI inputs to no avail.
    I do notice that 2 of the power supply capacitors are rounded (C261 and C263) of which I am thinking of replacing just in case it may solve a power supply problem.
    Any suggestions?
That happened to my lcd monitor, but it would only happen sometimes when something else in the house was switched on, like a light in the next room. i would hear the light switch be flicked and the tv would black out for a couple of seconds...
Posted on Aug 27, 2008
    Scholar:
  • 146 Answers
Does your monitor have an external transformer as the psu ?
If so, try disconnecting at mains for about 5 seconds and re-connect. failing that we'll need to dig deeper.
Posted on Jan 06, 2008
  • martin hogg Jan 06, 2008
    whether the psu transformer is internal or external, from what you say, it does definitely sound like a power supply problem, possibly a faulty internal connection which intermittently makes/breaks the connection........if there is an inspection panel covering the video input from the pc, it may also be worth checking the security of the connection on the vga plug, making sure that the captive screws at both the pc and screen ends of the vga lead are secure, as slack screws can cause faulty connections.....if all is well and fault remains, then take it back to your point of sale. Personally if an item is still under warranty, I would simply take it back and demand a replacement !
Power
Check for a loose power cord on the back of the monitor (quite common).
Jan 29, 2018 | Sony SDM-HS95 19" LCD Monitor
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Black screen
• 1) TAKE OUT YOUR LAPTOP BATTERY
• 2) REMOVE YOUR AC ADAPTOR CORD, that's the wall power, remove it.
• 3) NOW HOLD DOWN THE POWER BUTTON FOR 30 SECONDS.
That will drain any static electricity that has built up on your laptop system board and many times fixes the problem of a black screen. After the 30 seconds re-connect your laptop to the wall power and hit the power button normally and see if the laptop comes back up.
Replace your battery.
Restart!
Mar 02, 2010 | Dell UltraSharp 2407WFP 24" LCD Monitor
Picture goes black at random intervals
There are 4 c5707/5706 in the inverter transformer driving circuits, the cause of the problem was due to poor solder connection in the bias circuits of the transistors. Make sure to check that after you install the new transistors otherwise you will blowthem up. Common problem with this model. When the circuit drwas too much power from the power supply, it will shut itself off to ptotect itself.
Dec 16, 2009 | Dell E173FP 17" LCD Monitor
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
My monitor goes black for about 2 seconds then goes back to pict.
Sounds asif the Xenon tubes that backlight the LCD are losing power. Probable cause, a power invertor or PSU fault.
It can be repaired by a hardware specialist, but best written off.
The cost of repair will be better spent on a new monitor.
Mar 19, 2009 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
Hitachi CML174SXW B randomly goes black
Have you noticed if the monitor gets hot before it turns off?
Please, don't open a monitor and try to repair it yourself. It can be very dangerous and it's not worth getting injured.
Jun 18, 2008 | Hitachi CML174SXWB (Carbon) 17" LCD...
Computer Monitor
hmmm chek the power board in the back chek resistors and ic's in ocilloscope good luck
Oct 12, 2007 | Daewoo L700C 17" Flat Panel LCD Monitor
ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
Samsung SyncMaster 205BW LCD Monitor Logo
543 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
