Question about Canon PIXMA iP3000 InkJet Photo Printer
Problem with pixma ip3000
Message is "print head not installed!"
when i try test print from printer direct, yellow led blink 5 times. i saw in user manual - the same problem.
please help me :(
  • misa_ks Jan 08, 2008
    same problem is when i print test page without pc.
  • 56 Answers
Try to reinstall the driver for the printer, sometimes this helps fix small errors like this.
Posted on Jan 06, 2008
Canon inkjet PIXMA ip3000 wont print and has 5 blinking yellow lights
Canceled the jobs on PC and verify the inks.If you use the refill inks perform the head cleaning in the mantenance mode.
Feb 13, 2013 | Canon PIXMA iP3000 InkJet Photo Printer
5 yellow blinks and nobody else ,
Issue: Alarm / Power light flashes orange 5 times consecutively (Print Head / Cartridge Error)
Solution: Reseat the print head iP3000
  1. Confirm that the printer is powered on.
  2. Open the paper output tray and top cover.
    Note: Gently open the paper output tray while holding it.
  3. After confirming that the print head holder has moved to the center, open the inner cover.
  4. Remove all ink tanks
  5. .Raise the print head lock lever and remove the print head.Re-seat the print head into the print head holder and lower the print head lock lever until a click is heard.Insert the appropriate ink tank into the slot at the right end and push down on the PUSH mark on top of the ink tank until a click is heard. Install the other ink tanks in the same manner.Close the inner cover and top cover.Properly installed: Note: Check that each ink tank is installed in the correct position
Solution: 2 Reset the printer
Resetting the Printer By resetting the printer's power, the print buffer is cleared and certain sensors are reset. If there is invalid data in the buffer, or sensors are stuck in a particular mode; errors may occur. Follow these steps to reset the printer:
  1. Turn the printer off with the Power button (if available).
  2. Disconnect the data cable from the printer (not applicable to WiFi, Bluetooth or Infrared) .
  3. Unplug the printer's power cord for approximately 10 minutes, and then plug it back in. If troubleshooting a communication issue, reconnect the data cable (not applicable to WiFi, Bluetooth or Infrared).
  4. Turn the printer back on.
Aug 30, 2011 | Canon PIXMA iP3000 InkJet Photo Printer
Canon printer IP3000 5 lights flashing
If its just orange led flashing .. You need to replace the print head..
if its cycling 5 times between orange and green than there is a problem with the ASF cam sensor (which means paper feed unit)
Mar 30, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Canon pixma ip 3000 error message printer is offline
If the orange lamp blinking only it's the print head is not installed, or it is not properly installed.Open the cover remove the print cartridges then remove the print head and put back it on.If not help the print head is defective and need replace.
If the orange lamp blinking with green alternately it's ASF (cam) sensor error.The problem is in sheet feed unit.
Oct 15, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 inkjet printer- print head is overheating
Try to remove the print head from printer and turn it on.If starts you need to replace the print head.It's part number is QY6-0064 becouse the old print head QY6-0034 is discontinued.
Oct 09, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Ip 4200 blinks 5 times
This error is the print head is not installed
[1401], or it is not properly
installed (Print head temperature
sensor error [1403] / Faulty
EEPROM data of the print head
[1405]).
Feb 06, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
5 flashes amber pixma ip3000 5 AMBER FLASHES PIXMA IP 3000
Try this link http://www.fixyourownprinter.com/forums/inkjet/27412
Stanr
Oct 02, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
5 amber flashes
Operator error.
Press printer's RESUME button.
If this doesn't clear the error, cancel printing and turn the printer off and then back on.
When press Resume button, ip3000 not responed(not print)
Aug 07, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
Nothing will print
5 times The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405]. Install the print head properly, and close the access cover. Or, with the print head installed, turn the printer off and on. This might help
Mar 10, 2007 | Canon PIXMA iP3000 InkJet Photo Printer
Canon PIXMA iP3000 InkJet Photo Printer Logo
208 people viewed this question
old marine
old marine
