Mitsubishi WS-55819 55 in. Rear Projection Television
Problem for Mitsubishi WS-55819 55 in. Rear Projection Television
Need assistance changing the convergence IC's
By jsjenterpris on Nov 09, 2009
Need assistance changing the convergence IC's -STK392-570... can I replace them with a standard soldering iron and non-lead solder? Are they mounted directly on the heat sinks?
Best Solution
posted on Nov 09, 2009
Very Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 937 votes
I have step by step start to finish instructions for this repair if you want them.
You can use regular solder--the original is lead free, it does not matter.
If you want the instructions rate this solution with 4 thumbs and I will post the instructions for you.
they will tell you everything you need to do the repair and step by step start to finish instructions.
SD TECH
Was this helpful?
Yes
No
4 people thought this was helpful
Popular Solutions for Mitsubishi WS-55819 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55819 55 in.
Do you recommend Mitsubishi WS-55819 55 in. Rear Projection Television?
Answer
Answer
How do we set the channels on hedallion hd 1080? We need to get it set to channel 3 to make dish... (More)
Answer
How do I get Picture in Picture, select and change channels in each?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(21591) 042-9690
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
