Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Not rolling properly
I have the powerbrush steamer and it is not rolling properly. Catches on the carpet.
  • Anonymous Jul 24, 2008
    The brush is not rolling properly. What do I do?
Nothing is loose, but the roller just flops around instead of pressing down on the carpet. That lets the clear nozzle drag on the carpet. It seems there should be a spring of some sort pushing the roller down. How to get in to see if the spring is broken or whatever?
Posted on Apr 10, 2009
    President:
  • 1,673 Answers
Sounds like the front of the nooze isn't seated with the base, or the clear window is loose. The base has a catch the lock the top housing together,
Posted on Jan 06, 2008
How can determine when it's time to replace the drive belt on my Bissel Power Steamer? Is there a certain number of hours of usage that I need to keep track of or does the belt replacement depend on the...
Usually, replacement is needed when the brush no longer runs or is intermittent. Check the brush bearings and for debris build-up whenever the belt is changed. Good luck!
Jun 12, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell carpet steamer not working
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
rtsdf
Feb 21, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I need manuals for my carpet steamer
Hi there its SmartAlec from NelsonVacuums.com.au. Judging buy the picture in your query you have a bissell. Lucky for you they have most of their user manuals online at bissell.com.au. Just type in your model to the search bar there and you should get access to all the information you need.
Happy Vacuuming!
Feb 08, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Wont **** up water
Go to bissell.com go unger frq.asked questions. Also check your belt
Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
How do i put belts on a bissell powerbrush steam cleaner?
If this is the model i'm thinking of. Make sure the units unplugged from the wall. There should be about six phillips head screws to remove. The motor should now be exposed. This is a good time to clean up the inside of the unit. Use liquid wrench or WD-40 and lubricate any moving parts. Make sure the brush is in good shape some require you to rotate or flip the brush to even out the wear. I hope this has been helpful.... : )
May 07, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
My Bissell Dirtlifter Powerbrush carpet cleaner will not roll. The back wheels roll fine, but when you put the machine down flat, the front part (where the roller is) sticks and will not roll.
I had the same problem. It would pull backwards but not go forward. A closer examination revealed the clear plastic part on the bottom in the very front of the machine had popped loose on one side.
If you look at the front of the machine, there is the clear plastic part on top where you see the dirty water being sucked up. The bottom half that creates the channel for the vacuum is where it came loose. It wouldn't create enough suction to draw the water up either. By taking out the two screws that hold the top part in place and removing it, I was able to snap the bottom back in. Works fine now. Hope this helps.
Apr 14, 2009 | Vacuums
I bought a Bissell 1695 power steamer from a friend without a manual with instructions nor the attachments. Can you help please??
Hello, I went to a local repair shop & was told that I may as well trash this Bissell 1695 model because very few parts were available & none were what I needed. Of course, I have to research things for myself & to try to keep from buying a new power steamer. Called Bissell Customer Service. CSR told me that the model was discontinued, none of the parts that I need are available & referred me to five authorized KY dealers (all of which are an hour or more driving time away). I am going to call all of them tomorrow & hope I can find a solution to one broken pivot arm that holds rotating brush roll. I found a helpful website that has a schematic and lists all parts that are available to order (& unavailable). There is also one service note regarding the parts that I need that says the entire base assembly with brush motor must be replaced because of a design change. Of course, it's not available either. Hope this helps some. The website is: hescoinc.com
Dec 19, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
213 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
