Question about Saeco Magic De Luxe Espresso Machine
Descaling i have a magic deluxe. anybody knows the descaling instructions?
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Posted on Jan 07, 2008
To descale or not to descale
Hi
Descaling is like changing the oil in you car. If you don't do it its not going to last. If you don't do it when it tells you and you have a lot of minerals in the water, those minerals will plug up the boiler and then you will have to replace it. Which is easier, and cheaper?
Apr 04, 2010 | Saeco Magic De Luxe Espresso Machine
How & where do I lubricate my Saeco Magic Deluxe?
Never.
The machine does not need lubrication, not even on the coffee grinder. If gears lubrication is needed, that is exceptional, and must be performed by the technician. Normally the machine must not be lubricated.
Regular maintenance includes cleaning and descaling, follow instructions from page 34 on the user manual downloadable here.
Regards.
Nov 29, 2009 | Coffee Makers & Espresso Machines
Would like to descale my machine without descaling solution, is this possible?
Ok guys this is my own opinion on descalling and I have to tell you firstly I have been repairing saeco machine for over 8 years so I think I know a bit about them by now. Scheduled Descalling to me is a waste of time and money, now I'M NOT saying to "never descale your saeco" but when that descale light or word comes up on your machine it does not necessarily mean your machine needs to be descaled. Your Saeco machine DOES NOT have a magical sensor inside that tells you there is calcium build up inside the boiler. All Saeco machine use a timer device built into the Electronic main board. As a pre set number of coffee's are made, Saeco has set a timer to bring up either a light or Symbol on screen to tell you your machine is in need of a descale. Now with different countries , States and living conditions not all water outlets consist of the same water purities, so how can Saeco say at a certain time your machine needs descalling? ( Saeco's are built in Europe were most places you wouldn't be caught dead drinking their tap water ) . I can only go by experience where I repair machines in Australia (Melbourne) and I have had many machines fail due to being constantly descalled. How many of you have been having a good run from your machine until the day you thought you had better off descale your magic deluxe as it hadn't been done in a while. Upon descalling the machine you hear and see water leaking from the unit and Bang , the machine stops dead , or if your very lucky you shut the machine off just in time before the circuit board gets wet and you send the Deluxe to Saeco and now your up for a new boiler and service.
What had happened is that in time the seals of the boiler have broken down and the calcium lining the boilers internal walls have been sealing the boiler from leaking. Upon cleaning the boiler , calcium is removed and the seals don't hold and you know the rest. I have personally given a machine to a family member and told them never to descale just to see what happens ( will the boiler go , or water stop flowing due to blockages? ) I can honestly tell you that this machine was made in 1996 and I had replaced the boiler 8 years ago , to this day the machine has not missed a beat and no leaks on boiler ( I have instructed them to regulary clean out brewer and lubricate seals ). Ah they hardley use it I hear you say , quite the contrary , Italian family, machine used every day and even taken once in a while to their local social gatherings making coffees for over 30 people. I also have a customer who every so often after 2 years will come back for a new boiler fitted ( machine used in pannel beating shop ) I told him to try not doing any descaling until he could see any water flow restrictions. It's been over 3 years now and I havent seen the machine back yet but I do time to time come across him and ask how the Saeco is going , he says "all is well". Now not doing a descale at all is madness as I have had many blocked or semi clogged boilers due to high calcium deposits ( expecially around the beach coast areas ) But if you feel that your machine is pumping a little less water and the brewer is clean from any blockages then a well deserved descale is probably needed. With older machines you only need to reset the descale light or display if not needed. With other types like Saeco Incanto you need to only go through the descale process without the additive or cleaning fluid introduced into the water tank and decsale will reset.I hope I have shed some light on this issue and I'm not trying to say Saeco are pulling the wool over your eyes when it comes to descaling. I am going by my experiences only and what I have seen during my time with these machines. Enjoy your Coffee
Apr 17, 2009 | Saeco Magic De Luxe Espresso Machine
Got an old saeco magic comfort 7/8 years old -
bye a good coffee descaler not vinager follow instruction on it normally fill the water tank leave room for the descaler start the machine open side valve leave it running for 15 second turn it off let it site for 10 to 15 minute after open valve for 30 second let it site for 10 minute and open valve repeat untill empty tank after clean water tank very good that descaler is acid nasty stuff after fill the water tank full of water start machine open side valve empty water tank that its good luck pierre p.s it take a while do descale good but worth it
Jan 02, 2009 | Saeco Magic Comfort Plus Espresso Machine
Magic Delux - Not heating
try to descale your machine to see if it helps.
Aug 24, 2008 | Saeco Magic De Luxe Espresso Machine
2nd light on the left is steadily lit
descaling time to reset the light i think you have to press the on buttom for 5 second if it doesnt reset let me know cheers
Jan 21, 2008 | Saeco Magic De Luxe Espresso Machine
Saeco Magic 2nd light to the left (ON RED LIT)
Sound like descaling warning light, need to run descaling solution through the machine (follow instructions, you can download a manual on saeco's website) this light can be turned off by pressing and holding the steam button for 5 seconds.
Saeco Magic Deluxe - trouble light on
Not sure which light you are refering to because the far right light shuld be temp ready light. The one you describe slunds like the descale light but that shouold be second to from the left. In which case it is telling you to descale. I can't attach a manual here so do a search for saeco repair and an authorized repair center should be able to get you one.
Aug 09, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Magic De Luxe Espresso Machine Logo
364 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
