Question about Intel Motherboard
FIC P4M 915G/PD1 system fails to Power Up
FIC P4M 915G/PD1 Intel P4 FSB533 HT ATI PCIE Display Adapter usual array of drives Musketeer Fan/Power Controller ? [hey... it came with the machine] Motherboard been running for about 2-3 years without problem. For convenience, I've always had the Windows Power Options set for "No Saving", i.e. leave everything on all the time. My conscience was **** by recent news reports of the combined carbon footprint of PC users who leave their machines running all the time. I went into Power Options and set the Display to go off after 2-hours and the system to "sleep" after 5-hours. Some days later I went to "wake-up" my machine but no joy! THE SYMPTOMS ARE: Hit the "Power On" button and all the fans fire-up, front-panel leds & lamps come on but as soon as I release the button it dies again. If I hold the power button on, power oscillates on, off, on, off continuously at about 1 - 2Hz. I HAVE TRIED: 1. clearing CMOS - no effect 2. removing all hardware a piece at a time - no effect 3. restored hardware but removed CPU - in this configuration the power supply starts normally from a single push of the power button? Likewise, switches off correctly after 4-second press/hold of power button. 4. replaced CPU with previously unused (i.e. out-of-the-box) Intel P4 and I'm back to the original symptoms... won't power-up from single button press and oscillates if button pressed & held. 5. Retained new CPU and removed Musketeer Power/Fan controller - no effect Finally, I don't get any beeps at all in any of the above mentioned configurations and I see no sign of bulging capacitors, pcb deformation or excessive heating anywhere on the board. QUESTION: At this point my guess best guess is a dodgy motherboard but if so, then how did this happen? Apart from overclocking [not possible with my system anyway] changing sotfware settings shouldn't lead to hardware failure! QUESTION: Could it be the PSU? Since it starts/stops OK without the CPU installed, is this really a possibility? QUESTION: is there anything else to try? Many thanks
  • Anonymous Jan 26, 2008
    Hi Rich, I have exactly the same problem and ive changed power supply, case cleaned it all out etc etc etc. I have also been on the very good www.experts-exchange.com forums and they all seem to agree that this problem is the motherboard being dead. Ok thats fine but the other problem is i can not find another one of these boards ANYWHERE so thats the next problem because if you have to use a different board then you have to repair the windows installation instead of just straight swap.
    Good luck! if i get any more news ill keep you posted
    Novelist:
  • 113 Answers
You should always try a new power supply if possible. After all, it is one of the most likely components to fail - it's got moving parts (one or more fans), just like your hard drive (spinning platters), one of the other most likely parts to die.
That said, in this instance it probably is the mobo. FIC made great motherboards, but they got out of the business so you won't find the same one anywhere. If you have to replace it, you may be able to get out of a Windows reinstall by getting a motherboard with the same chipset, which looks like a 915/G, though any 915 based board might do. You may still need to do a repair install, but in many cases the same chipset allows you to boot and then just load all the new different drivers for the new board.
Posted on Jan 27, 2008
Wanttodownloaddriversp4m-800t
Drivers are mostly operating system specific, so unless I know that I can't really help you. I recommend you contact your manufacturer (FIC)[http://www.fic.com.tw] about official drivers for the m/b, they only list the newer m/bs. Alternatively, you may try searching the internet for a driver download site, but be careful. (btw a manual for your m/b can be found here http://www.elhvb.com/supportbios.info/Archives/MANUAL/FIC/p4m-800t/p4m-800t_a0_eng.pdf)
Apr 23, 2014 | Intel Computers & Internet
P4m-915g/pdi needing motherboard drivers will not recognise disk drive is there even though can use to install windows
go to ftp://ftp.fic.com.tw/motherboard/driver/1stutilities_v1.27/
i hope this helped good luck
Nov 10, 2010 | FIC P4M-915PD1 Motherboard
I cant find where to connect the power cable?!
ATX Main Power (20-pin) is located next to the IDE-drives, the P4-connector (square, 4-pin) is a few centimeters behind the USB-ports.
Dec 10, 2009 | FIC P4M-865G MAX Motherboard
MEMORY FOR P4M-915G/PDI
That motherboard takes DDR2 Dual Channel Memory.
Jul 22, 2009 | FIC P4M-915PD1 Motherboard
Ethernet controller driver for P4M 915G/PD1
I think it realtek LAN card. You can download the driver from the following link and try.
ftp://ftp.fic.com.tw/motherboard/driver/1stUtilities_v1.27/LAN/
Nov 25, 2008 | FIC P4M-915PD1 Motherboard
Still haven´t got bios for P4M-915PD1
Hi, yeah I noticed that it took you too a ftp site. There are no new updates or old bios files for the FIC P4M-915PD1 throught FIC. They do not list bios files on their web site anymore. There is a link but it goes no where. Tried different countrys. Nothing.
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=159
So I went after you're chipset, which is an Intel. At this link.
http://www.intel.com/products/chipsets/915P/tools.htm#ddbios
Intel's link will not load the bios link. You're board is still an Intel & should be compatible with any Intel board with the 915 series chipset but it is not. After running a comparison with other boards as shown below. You're board was made for FIC. As a member of Driverguid I found nothing & also check every user who suggested a site for you as well. Nothing! Tried softpedia, nothing.
Not enough to support you're board.
Sorry, but it may be a good idea to find a board that will handel you're parts.
Mike
Apr 08, 2008 | FIC P4M-915PD1 Motherboard
Problems after Power Management changes
Experience a similar problem with a FIC MB. I cleared CMOS then removed MB battery for 1 hour. Restarted the unit with just the video card and hard drive installed. After unit rebooted I added sound card, network card, etc.
Jan 06, 2008 | FIC P4M-915PD1 Motherboard
P4M-915G/PD1 no screen, no BIOS, only power.
Do you hear any beeps at all? Do you have a system speaker on the motherboard? If not, plug a 2-pin system speakers onto the motherboard where it says "speaker" and listen for some beeps. You may have a fried CPU or dodgy RAM on your hands. Possibly even a faulty AGP/PCI-E slot, to name a few.
Sep 07, 2007 | FIC P4M-915PD1 Motherboard
Intel Motherboard Logo
338 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
