GE Side by Side Refrigerator
Problem for GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator side freezes on lowest setting
By pataustin327 on Nov 09, 2009
refrigerator side freezes on lowest setting
Solution #1
posted on Nov 09, 2009
Not Rated)
vladimir77
Rank: Guru
Rating: 95%, 38 votes
The air damper door is likely broken. Remove the cover inlet assembly and check. Located in the fresh food section on the top back. It looks like this, and this is what you most likely need to buy. Rotate picture 180 degrees, and you'll know what part it is.
How to remove it: Remove shelves, remove air duct on back (it's on clips) below the inlet cover assembly. Remove light cover and all screws holding the light fixture on top. Remove filter. Remove all screws holding the inlet cover assembly, including the one on the right, on the filter bracket. Disconnect wiring harness plug. MAKE SURE TO TAKE NOTES ON THE PARTS LOCATION OR TAKE PICTURES!!! It's not easy to put it back, so you need to know the exact interconnection of all parts.
Once you take the inlet cover assy off, look inside from the freezer side. The door is a black rectangle piece. It's supposed to be attached to the housing. If it's not attached - replace the whole cover inlet assembly.
Use coupon "New10" for 10%off
Was this helpful?
Yes
No
Solution #2
Not Rated)
nanbuenbrazo
Rank: Wiz  Refrigerators  Expert
Rating: 79%, 162 votes
Check your thermostat control, it may be faulty, it has a continuity but the sensor are not.
Was this helpful?
Yes
No
Popular Solutions for GE Side by Side Refrigerator
Questions and Unsolved Problems for GE Side by Side Refrigerator
Do you recommend GE (PSS26MSRSS) Side by Side Refrigerator?
Answer
Answer
I have a GE Profile Arctica side by side refrigerator. My ice maker has stopped making ice. Water is... (More)
Answer
We have a GE side by side model GSS23WGSCBB SN AL412914 that is approx 4 years old. There is a... (More)
Answer
I have replaced the mother board, damper and fan and my fridge still isn't getting cold on the top... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE Side by Side Refrigerator:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
