Home | Dell | Dimension 4600 PC Desktop | Computer will not tur...
Dell Dimension 4600 PC Desktop
Problem for Dell Dimension 4600 PC Desktop
Computer will not turn on. " in power save mode"
By PASupport on Nov 09, 2009
Computer will not turn on. Light in front of the computer blinking. When I press a key on the key board a message comes on the screen and says " in power save mode " not sure what this is. I unplugged the computer and plugged it back in and keep getting the same message. I would be greatly appreciated it if someone could help. Thank You.
Comments:
Nov 09, 2009
- Tried everything. Just pressed the power button, held it and still nothing. Only thing that I can think of is that the power supply is bad? Thank You for such a fast response and hope you can help.
Nov 17, 2009
- Ok, so I unplugged everything inside of the computer to use less power to see if that was what was the problem. Didn't work but when I unplug the hard drive, compuer will turn on and go to setup. So it looks like the probem is from the hard drive but now stuck again because what would be causing it not to turn on when hard drive is plugged in?
Clarification Request
Posted by ethan859 on Nov 09, 2009
Have you tried pushing the power button? Not holding it, just pressing it?
Best Solution
posted on Nov 09, 2009
Very Helpful)
ethan859
Rank: Master
Rating: 92%, 3 votes
If mbase213's solution doesn't work, try the solution I've found in another forum. Read through the whole thread.
http://en.kioskea.net/forum/affich-46233-can-t-exit-power-saving-mode
Was this helpful?
Yes
No
1 person thought this was helpful
Asker's Testimonial
" Thank You. " - PASupport
Solution #2
Somewhat Helpful)
mbase213
Rank: Guru
Rating: 91%, 195 votes
When your computer initially turns on, do you get a beep? Once you get a beep, it will show a screen that allows you into the bios. By either hitting, the del key, or F1 or F2, it will tell you on the post screen. Once your inside the Bios, go to power, and unclick the button that says, place in power save, That should do it.
Good Luck
Mark
Comments:
Nov 17, 2009
- Did you check your pin settings on that hard drive?
Mark
Was this helpful?
Yes
No
Popular Solutions for Dell Dimension 4600 PC Desktop
Questions and Unsolved Problems for Dell Dimension 4600 PC Desktop
Do you recommend Dell Dimension 4600 PC Desktop?
Answer
Answer
System inoperative. Keyboard lights are on, power indicator lights are lit, cant tell if hard drive... (More)
Answer
I have a Dell Desktop , bought a cable to hook it up with my tv, also using a hd15 vga splitter,... (More)
Answer
HP Pavilion Slimline s3122x powers up fan runs but no monitor working or keyboard took to shop was... (More)
Answer
how can i clean my comp. drivers for free
Answer
dvd does not read the disc although the drive is spinning
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Dimension 4600 PC Desktop:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
