Question about Sony Ericsson Walkman W810i Cellular Phone
Email settings i need a server name annd a ip adress
    Brigadier General:
  • 7,752 Answers
You will have to get that from your service provider
Posted on Jan 20, 2008
Hi ..I can't connect to my yahoo messnger..And it says here's the problem..hope u can help me.. Checking virtual IP servers... [VIP Raw] Resolving host name vcs1.msg.yahoo.com... [PASSED] [VIP Raw]...
can you get an internet connection?
click start control panel internet options you will see a home page box To Create Page Tabs type each adress on its own line (type in yahoo.com)
check your firewall settings make sure yahoo is allowed
click start type in cmd press enter
you should have a black screen you are in dos mode
type in ipconfig
you should see all of your connection details
type in your default gateway adress into your browser (search engine)
hope this helps you
Oct 18, 2011 | Yahoo Messenger
I would like to scan a color picture and send it to my e-mail address. What are the exact steps to do this.
Type the machine ip adress on the adress bar of the machine and hit enter.
Then the machine webpage will appear
1. Click the Network Settings link, login asadmin, username is admin and password is also admin and click the Services Settings link.
2. Use the SMTP server IP addresses in the Primary andSecondary Server fields rather than the server names.
3. Verify if the mail server is using the default SMTP portof 25. If it is not, then change the Port Number to match the server. Port 587is a commonly used port if authentication is required.
4. The Reply Email Address must be a valid local emailaddress for some mail servers or messages will be discarded. If using a Reply Email Address like: noreply@whatever.comor scanner@whatever.com confirm that the email address actually exists.
5. If the server is running SSL (GMail uses SSL) for bettersecurity, check the box next to Enable SSL. Click here for instructions on how to setup scan to GMail.
6. Leave the User Name and Password blank temporarily andperform the Connection Test. A successful response will verify that the serveris really a valid SMTP mail server.
The following should be performed byan I.T. person
Mail server settings
1.Createa new user account and password for the mfp on the mail server this useraccount name , the name set in the mfp
Apr 08, 2011 | Sharp MX-2700N Color Copier
Cannot see server
check ipconfig if ur ip adress is correct configure Ip address statically but then be carefull that u dont duplicate another Ipadress already on network
make sure gateway ip adress is correct as well as dns server ip adress
try to add urself to the domain check if your pc name is correct
Sep 01, 2009 | Computers & Internet
I can't get exchange to smtp out. godaddy was the email host but they weren't very helpful and change MX to point to my server. Now it's worse... can't get incoming or outgoing.
1. The mx record has to be changed to an adress, which can be reached from the internet. It has to be an public IP Adress or you have to use dyndns.org or something like that. If the Server is not reachable directly in the Internet, you have to set your Internetrouter to forward smtp to your server in your network.
2. There are cases, when you need to configure a Smart Host for your e-mail server. A typical example is the situation, when your ISP blocks outbound connections on TCP port 25. Another, very common case is when you are using an IP address which belongs to a range of Dynamic IP addresses. It is a common practice to drop smtp connections or discard e-mail messages sent from a dynamic IP address.
a. Open your Exchange System Management Console - Administrative Groups - "Groupname" - Server - "Servername" - protocols - smtp.
b. Click right to"virtual standard server for smtp" and choose properties.
c. Change to tab delivery.
d. Then choose the button advanced.
Here you can set the full qualified domain name and you can set a smarthost entry. May be this helps
take also a look at http://codebetter.com/blogs/john.papa/archive/2007/04/02/Problems-Sending-Mail-on-Dedicated-Server-with-GoDaddy.aspx
May 22, 2009 | Computers & Internet
Gprs setting
I think you are asking for the phone settings for airtel gprs. Since you haven't mentioned whether you want for airtel live or mobile office, i've provided you both.
Airtel live:
Connection Name> Airtel Live
Data bearer>gprs
Access point name>airtelfun.com
User Name/Password>(leave blank)
Authentication>Normal
Homepage>live.airtelworld.com
IP Address>100.1.200.99
Connection Security>Off
Session mode>Permanent
Mobile Office:
Connection Name>Mobile Office
Access Point Name>airtelgprs.com
Homepage>www.google.com
IP Address>0.0.0.0
Manual Airtel Gprs Settings
  1. Homepage - any page you want to set.
  2. User Name - Blank
  3. Password - Blank
  4. Proxy - Enabled/yes.
  5. Proxy and Server Adress - 202.56.231.117
  6. Proxy and Server Port - 8080
  7. Data bearer - GPRS or Packet Data.
  8. Access Point Name - airtelgprs.com
  9. Authentication Type - Normal
  10. Use preferred access point - No
Manual Airtel live settings
  1. Account Name - Airtel_live
  2. Homepage - http://live.airtelworld.com
  3. Username - Blank
  4. Password - Blank
  5. Proxy - Enabled/yes
  6. Proxy and Server Adress - 100.1.200.99
  7. Accespoint Name - airtelfun.com
  8. Proxy and Server Port - 8080
  9. Data bearer - GPRS/ Packet Data
  10. Authentication Type - Normal
Hope it helps.
Mar 21, 2009 | Sony Ericsson w580i Cellular Phone
How do i set my Netgear Routers NAT type to open for playing xbox 360 games?
I assume you know the ip adress of your xbox.
First of all check on your router to see if UPNP is enabled.
Then go to Portforwarding/Port triggering.
Then add custom service
service name: the name of how you call it. doesn't matter really
service type is UDP
start port 88
end port 88
server ip is the adress of your xbox
then apply and make another custom service
name it how you want
service type tcp/udp
start port 3074
end port 3074
server ip adress of you xbox
this should work
Jan 03, 2009 | NetGear WGR614 Wireless Router
Unable to create an email address on a Imagerunner 3220
Hi Keeyan.
Fist you will need a send kit only supplied by your dealer.
If this funcktion is inable follow these steps.
Press the user button(it is the button with the star)
Select system settings,network settings-in network settings go down wit the arrow until you get e-mail/i-fax settings.(If it is not showing here or in tcp/ip settings the send kit might not be enabled)
In e-mail settings enter the smtp server name or ip address(you will find it on your computer in outlook under tools and acounts)
In the email you can enter a email address supplied by your network adminitrator.
If you have a DNS server insert the ip adress of the DNS in TCP/IP settings.
Make sure you IP addres is also correct.
Then you are ready to go
Nov 21, 2008 | Canon imageRUNNER C3220 Color Copier
Email Address Problems
You must enter a DNS server on the "Network Settings > TCP / IP" page. If you're unsure of it, try copying your default gateway.
Jan 31, 2008 | Samsung CLX 3160fn All-In-One Printer
Dns error 80710102
Hey peterk18,
First of all, how is your network configured? Are you behind a router? What's it's IP adress, does it act as a DHCP server?
If so try to set up a new network connection and put everything to automatic.. When the routers acts as a DHCP server it will give the PlayStation 3 an IP adress. DNS however is something else. DNS is a system that allows you to browse by a website or hosts name. For example: it allows you to type www.google.com in your browser instead of it's IP.
DNS is essential for Internet. Your router should be your DNS server and your router itself also needs to know a DNS server, this would be the server from your ISP. All these settings are automatically configured via DHCP.
Greetings,
DarkNeogen
Jan 12, 2008 | Sony Playstation 3 (PS3) Console
Sony Ericsson Walkman W810i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
