Question about Panasonic SC-DT100 System
I need help fixing my DVD-PLAYER. The model number is- PANASONIC SC-DT100. The problem with my DVD-PLAYER is that it won't play original DVDs, it used to before but not anymore. I some how did something that won't let me play original DVDs anymore, it only lets me play copies. I hope you can help me. Thankyou.
  • 2 more comments
  • ZAINAB786 Jan 08, 2008
    When I put original discs into my unit it says that "this disc cannot be played in this region". My discs used to work perfectly before up until now. I did not try to region hack my unit. I did not use a lense cleaner either. How do I set my region number? My region number is 2.
    Please can you tell me were i can get this DVD cleaning set from? And please can you also tell me how to set my region code.
  • ZAINAB786 Jan 17, 2008
    HOW DO I SET MY REGOIN CORD?
  • ZAINAB786 Mar 05, 2008
    I cleaned my dvd as you said but, it still wont play original dvds. have u got other opption also wha ts this about a disc that unlocks codes.zainab
    Brigadier General:
  • 3,614 Answers
Various issues can cause drives to occasionally balk at writing optical discs. These run the gamut of physical, hardware, and software troubles.
Inappropriate or dirty media may be to blame. Make sure to match the type of recordable disc to the drive, and check each disc for fingerprints or other contaminants. If a disc is dirty, wipe it with a clean, soft cloth in a straight line from the center hole outward. Try a quality optical drive cleaning disc if you suspect dust contamination on the drive’s laser lens.
Some discs don’t perform well with certain drives, even within their rated speeds. Try recording at a slower speed and then with a different brand of disc. Also, on PCs, verify that the temporary file storage area on the hard drive used by the burning software has enough free, defragmented space. Allocate at least 5GB for a DVD (9GB for a double-layer [DL] disc) and about 1GB for CD burning.
Posted on Mar 05, 2008
    Novelist:
  • 167 Answers
I read on a forum that someone bought the info from http://www.dvdunlocks4u.com/ and it was only $8.99, and it worked to make their SC-DT100 multi-region. There was no "special remote" or "Special disk" needed. They will just e-mail you and tell you exactly what you need to do.
That may be your cheapest/quickest solution.
Posted on Jan 17, 2008
    President:
  • 1,944 Answers
What happens when you put in an original disc? Are these the same original discs that you have used in the past on this unit? Did you try to region hack your unit? Did you try using a lens cleaner?
Posted on Jan 06, 2008
  • 2 more comments
  • Damen Wong
    Damen Wong Jan 06, 2008
    Your unit should be set to region 1. Are the original discs from another region?
  • Damen Wong
    Damen Wong Jan 09, 2008
    You can get a DVD/CD lens cleaner set from most electronics/computer shops. Just go to your local electronics/computer store to buy one.
    Regarding region free...you will need to purchase a Panasonic service disc.
  • Damen Wong
    Damen Wong Jan 17, 2008
    There is no way to make your unit region free just by punching in codes on your remote. You need a panasonic service disc. You can get the disc from here:
    http://www.dvd-hacks.co.uk/panasonic.htm
  • Damen Wong
  • 689 Answers
Hi Zainab
The issue usually related to more than one possibilities. First possibility; the obstacle in front of laser beam lens. Sometime by natural causes the DVD lens collect tiny amount of dust which makes the laser reflection on CD weaker. since copied DVDs has different track structure it might be better reflected.
Second possibility is your region code has been changed. Copied DVDs usualy come with region "0". You might try to set your region again.
You may perform lens cleaning by obtaining an easy to find DVD cleaner set.
Please post if you have further questions
Good Luck
DVD player does not recognize DVDs.
if your trying to play dvd r or dvd rw ( copy dvds ) some dvd players wont play them. but if its original dvds your trying to play, try using a lens cleaning kit
Oct 12, 2011 | Panasonic DMR-ES46VS DVD Recorder/VCR
How do i connect my sytem directly to the tv not just the dvd player?
Connect to the audio out of the TV, assuming you have a RCA audio out (red/white) on the TV. (Audio out of the TV to one of the Audio in of the SC-DT100)
The manual for the SC-DT100 is available from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Audio/Home-Theater/Home-Theater-Systems/model.SC-DT100 .
Some new TVs only have digital audio out, this isn't compatible with this home theater system's inputs.
I hope this helps.
Mar 09, 2011 | Panasonic SC-DT100 System
I am in Australia and have a Panasonic SC-HT878 DVD player that plays PAL DVDs fine through my TEAC TV but when I play NTSC DVDs I only get a black and white picture. How do I fix this so my NTSC DVDs play...
There should be a setting on the DVD's menu for output of picture. You should look under colour settings, to see if it has got NTSC output. You should also check your TV it might not be set to NTSC aswell. You can look in the user manual of the DVD to see if says anything about NTSC playback. If you have lost the manual you can download it for free on the Panasonic website.
If it won't playback NTSC discs, I'd guess you can get an adapter from somewhere.
Jan 29, 2010 | Panasonic SC-HT520 System
Panasonic SC-DT100 flat cable
ON SCDT100 has only TV/AUX IN the flat cable is only for Panasonic Devices, so you only option has TV/AUX IN,you need the comb. AV cable from WD media player and connect to TV/AUX INPUT
Jan 17, 2010 | Panasonic SC-DT100 System
Unlock code to unlock dvd player to play dvds from all regions
0082 0015 0089 0004 00F2 0033 0017 0010 0091 0013
make sure you have the disc draw open and enter the above code via your remote.
let me know if it works
Jan 10, 2009 | Televison & Video
It wont play dvds!!! Help!!! Panasonic SC-HT520
You can try a CD/DVD Cleaner Disk ($3-$5). Some sell for $15, don't know if you'll get better results. If it doesn't work, then you have a laser alignment issue that needs calibrating. The labor is likely to cost more than a new DVD player.
Dec 28, 2008 | Panasonic SC-HT520 System
Region/zone unlocking Panasonic SC-PT150
This dvd player is zone free.
The following is just a few of the Panasonic SC-HT150 Features:
All region (Regions 1-6) playback
Lifetime warranty on our modifications: We totally stand behind the DVD players we sell. We guarantee that your code free player will play any region DVD from any country in the World. If your DVD player ever becomes defective we will fix it for free!
Guaranteed to play all old, current and future DVD movies including DVDs that are RCE coded
PAL/NTSC Playback of DVD/VCD
To play PAL movies you need a PAL TV or a Video converter
World Wide Power Supply: 110-240 volts 50-60 hertz
Playable Disc Type
For more information http://www.samstores.com/details.asp?ProdID=9617
Dec 17, 2007 | Televison & Video
How can I unlock my dvd player to play American dvds please?
I have a panasonic DMR-EZ45V which only plays region 2, but some dvds i want are on only on region 1, can it be changed to play both regions?
willc
Oct 26, 2007 | Panasonic DMRES30V DVD Recorder/VCR Combo
PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Aug 01, 2007 | Panasonic SC-DT100 System
Panasonic SC-DT100 System Logo
194 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
