Microsoft Windows XP Home Edition
Problem for Microsoft Windows XP Home Edition
I would like my pc to be set the way it used to
By roydawg2020 on Nov 09, 2009
I would like my pc to be set the way it used to be.
Solution #1
posted on Nov 09, 2009
Not Rated)
hansola
Rank: Wiz
Rating: 84%, 10 votes
I can help you set it up the way you like but need more info. What exactly do you want to change? Xp appearance? What happened that it is not setup that way anymore? Maybe we can just restore some settings and everything will revert back to the way they were.
Try this for starters:
RIGHT-Click on START
Select properties
If "start menu" is selected, click the selection for "classic start menu"
If "classic start menu" is selected, click the selection for "start menu"
Interested in getting more input.
Hope this helps!
Was this helpful?
Yes
No
Solution #2
Not Rated)
NinaE
Rank: Guru
Rating: 86%, 321 votes
Hello, Roy.
Your question is not clear - do you want your computer to work better ? Do you want your computer to go back to the way it was when you purchased your system ? What problems are you experiencing ??
But, I will give you a few suggestions ... if you are experiencing problems with your computer and want to roll back to an earlier time when everything worked, I'd suggest System Restore. Go to Start - Programs - Accessories - System Restore. If you want your computer to go back to the way it was when you purchased your system, use Factory Restore.
You need to provide more info to us, such as your brand and model of computer, for FixYa to assist you further.
Hope this helps.
Was this helpful?
Yes
No
Solution #3
Not Rated)
swoop611
Rank: Wiz
Rating: 83%, 49 votes
This is a little vague but I guess you want to reset your PC back to an earlier version.. Click on start, Select help and support. In the windows that opens, select undo changes with system restore which is in the right column under TASKS. when the next window opens, select restore my computer to an earlier time and calendar will open. the days that are highlighted are days that you can restore your pc back to. select a highlighted date and click on next. Confirm your selections and the machine will restore itself to the selected date. This may take some time. Once your PC has rebooted, it should be in the same state it was on the date you chose and any changes made after that date should have been removed.. It is a good idea to set a restore point before you change anything or install new software as this allows you to reset any changes and return your setup back to a known good state. You set a restore point through Start, Help and Support, Undo changes with system restore but you must click on the "create a restore point" option. Type in a name for the restore point and click next..
Was this helpful?
Yes
No
Solution #4
Not Rated)
argospete
Rank: Wiz  Computer Software  Expert
Rating: 72%, 70 votes
Backup all your important data/files/emails.
Format c:
Reinstall from supplied setup discs, if no discs, make copies from onboard copy setup disc function!
Was this helpful?
Yes
No
Solution #5
Not Rated)
VinayT
Rank: Wiz  Microsoft Computer Software  Expert
Rating: 81%, 862 votes
The Way it use to be, When? Remember the date and restore the PC to that date or somewhere then, a few days here or there. How??? Go to Start->Accessories->System Tools->Restore. The PC would take a reboot before you are shifted back in time. But it would be restored to that date which is bold in the calender.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Windows XP Home
Questions and Unsolved Problems for Microsoft Windows XP Home
Do you recommend Microsoft Windows XP Home Edition?
Answer
Answer
how can i stop my music from sticking and faltering when i am playing my downloaded music
Answer
remove emails from mail talktalk net they will not delete
Answer
how do you get more cannels on an asio sound driver
Answer
I can surf most sites but others including sign ons I losethe conection I run a diagnostic and it... (More)
Answer
i can get the m audio 1x1 to play sound its not coming out. but it going thourgh but on the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Microsoft Windows XP Home...:
Top Operating System Experts
Rank: Guru Guru
Solutions: 1451
Experience: I have owned a computer networking sales and service company.
Ask Me
Find more Operating System Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
