Question about Samsung HCM4215W 42" Rear Projection Television
Samsung rear projection tv
I have a problem with my samsung 42" rear projection tv the colours on the screen are starting to seperate is it worth repairing
  • Anonymous Oct 21, 2008
    similar problem tried to converge colours but red seems to be the most prominant double vision
Cant align convergance
Posted on Oct 23, 2008
It probably is see if you can align the convergence manually or auto if available, you can order just the convergence ic's or the convergence amp board, whichever you prefer. check pricing and availability. also check Blue crt for faded picture, usually dirty crt fluid, makes picture dark and discoloured. If it is you may need to replace the blue crt also. this gets a little expensive, again check pricing hope this gets you started RFT
Posted on Jan 06, 2008
6ya staff
SOURCE:
Colour has screwed up
Call Encompass Parts Distrubtion 1-800-638-3328 its either your DMD board 180.00 or Light Engine and they do not have any in stock Cost $1,056.00 Try UED 1-800-648-6657>
Dec 31, 2009 | Samsung HLN5065W 50" Rear Projection...
When switched on colours fine after short period colours seperate causing a 3d type effect
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 21, 2009 | Samsung HCN4226W 42" Rear Projection...
Samsung Rear 42 in Projection TV Calibration problem
Hi, if you are not able to adjust the convergence using the remote you will need to replace the convergence chips.
Typical Symptoms
1) Convergence menu does not work for one or more colors.
Such as: Red moves up,down, but left or right fails.
2) Screen is bowed looking.
If you have one or more of the problems above you need to replace the convergence chips. You can get a kit and instructions from www.TvRepairKits.com
Hope this helps :)
Jun 16, 2009 | Toshiba 62HMX84 62" Rear Projection HDTV
My tv has lost its colour, and its green or yellow sometimes.
Okay that means the other GUNS went out when i refer to guns I mean the other blue and red, they need to be replaced pretty costly but if you value that TV I'd do it.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Apr 22, 2009 | Samsung HCN4226W 42" Rear Projection...
My tv turns onn for a few seconds then shuts off
it can be repaired but it would be easier to buy a new tv and cheaper
Oct 22, 2008 | Samsung HCM422W 42" Rear Projection...
Ghost like shadows
It seems your TV Samsung HCM4215W has problem in convergence board and need to be replaced.
You can get that board from Parts Store on $76
If you have bit electronics knowledge and know how about tv repair, you can replace it by yourself or get help of local tv tech person.
Oct 06, 2008 | Samsung HCM4215W 42" Rear Projection...
The colors primary red,green and blue malfunction
the convergence ICs are most likely the cause of your problem. You can get replacement ICs at the following link with free instructions.
http://servicemanuals.vstore.ca/
Sep 14, 2008 | Samsung HCM4216W 42" Rear Projection...
61 in RCA Rear-Project color seperation
Your used TV is not worth much. Let us not fill our land fills with TV's. You may give it to a charitable oranganization (tax deduction) or local school that has an electronic course. Enjoy your new LCD you a great choice in type and brand.
May 04, 2008 | RCA P52926 52" Rear Projection Television
2006 42'' Samsung rear projection, Balist????
A Ballast is a circuit that provides voltage to Lamp. Ballasts are only used with TV's with a Lamp. According to your model number this unit does not use a lamp. That model number uses 3 rear-projected CRTs. The most common units with a ballast would be a DLP HDTV.
The Model number you specified HCN4226W is a unit made in 2003. However you stated in your subject line that this was a Samsung unit from 2006. Please verify your model number.
Feb 29, 2008 | Samsung HCN4226W 42" Rear Projection...
Rear screen tv
flayback transformer or tv tube.
i would think it's worth reapir.
Nov 26, 2007 | Toshiba 42H83 42" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
181 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
